跳转到主内容
Cingular 8125 Speakers Replacement
你所需要的
    • Hold the phone with the back (camera side) facing you.
    • Press on the battery cover until it slides off.
  1. Cingular 8125 Speakers Replacement: 步骤 2 中的图像 1,1
    • Lift up the black tab that sticks out on the battery's side until the battery is pulled out.
    • Using the iFixit Opening Tool, pull on the phone's camera cover until it pops off.
  2. Cingular 8125 Speakers Replacement: 步骤 3 中的图像 1,1
    • Remove the four black Torx head screws in each corner.
  3. Cingular 8125 Speakers Replacement: 步骤 4 中的图像 1,1
    • Pull on the back cover of the phone with the iFixit opening tool until the green motherboard is revealed.
  4. Cingular 8125 Speakers Replacement: 步骤 5 中的图像 1,1
    • Remove the black plastic piece from the motherboard by gently pulling it off.
    • Align the white squares on the motherboard and the speakers.
    • You'll know they are lined up correctly when the speaker's wires face the motherboard's center.
    • Press down on the white squares until they snap together.
  5. Cingular 8125 Speakers Replacement: 步骤 6 中的图像 1,1
    • Place the back cover of the phone over the motherboard.
    • Check to be sure the speaker's black piece is against the holes in the back cover.
    • Screw the four Torx head screws with the 64 Bit Driver Handle to connect the back cover to the motherboard.
    • Press the camera cover down on the back cover until it snaps into place.
    • Line up the copper terminal on the battery with the terminal on the phone, then press the battery back into place.
    • Make sure the black tab sticks out.
    • Slide the battery cover over the camera cover until it snaps back into place.
结论
Laura Kimberly Simonds
于09/24/12注册
301 声望
创作了2篇指南
团队
University of Maine, Team 1-1, Diaz Fall 2012 University of Maine, Team 1-1, Diaz Fall 2012 的会员
UMAINE-DIAZ-F12S1G1
4 名成员
创作了2篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 13
总计 371
