跳转到主内容
Cineyo BT-03 Device Battery Replacement
你所需要的
  1. Cineyo BT-03 Device Battery Replacement, Cineyo BT-03 Device Disassembly: 步骤 1 中的图像 1,3 Cineyo BT-03 Device Battery Replacement, Cineyo BT-03 Device Disassembly: 步骤 1 中的图像 2,3 Cineyo BT-03 Device Battery Replacement, Cineyo BT-03 Device Disassembly: 步骤 1 中的图像 3,3
    • Remove the top (button side) rubber cover using your hands.
  2. Cineyo BT-03 Device Battery Replacement: 步骤 2 中的图像 1,2 Cineyo BT-03 Device Battery Replacement: 步骤 2 中的图像 2,2
    • Flip over the device and remove the bottom rubber cover using your hands.
  3. Cineyo BT-03 Device Battery Replacement: 步骤 3 中的图像 1,3 Cineyo BT-03 Device Battery Replacement: 步骤 3 中的图像 2,3 Cineyo BT-03 Device Battery Replacement: 步骤 3 中的图像 3,3
    • Using your hands, pull off the plastic side cover (on the side with the audio jack) using the indented tab. The indented tab has been highlighted in the picture.
  4. Cineyo BT-03 Device Battery Replacement: 步骤 4 中的图像 1,3 Cineyo BT-03 Device Battery Replacement: 步骤 4 中的图像 2,3 Cineyo BT-03 Device Battery Replacement: 步骤 4 中的图像 3,3
    • Detach the plastic speaker cover on both the front and back sides. Then slide the cover off of the device.
    • The cover should remain as one solid piece.
  5. Cineyo BT-03 Device Battery Replacement: 步骤 5 中的图像 1,1
    • Remove the five 1 cm screws on the back side (opposite of the speakers) of the device using a Phillips #1 screwdriver.
  6. Cineyo BT-03 Device Battery Replacement: 步骤 6 中的图像 1,1
    • Gently pull apart the two sections of the device.
  7. Cineyo BT-03 Device Battery Replacement, Battery: 步骤 7 中的图像 1,2 Cineyo BT-03 Device Battery Replacement, Battery: 步骤 7 中的图像 2,2
    • Pull the wires connecting the blue battery out of the circuit board.
  8. Cineyo BT-03 Device Battery Replacement: 步骤 8 中的图像 1,2 Cineyo BT-03 Device Battery Replacement: 步骤 8 中的图像 2,2
    • Using your fingers, pull the blue battery out of the casing.
    • There might be slight hesitation due to the adhesive attaching the battery to the casing, so a slight bit of force might be necessary.
结论
Cole Crawford
于02/13/17注册
85 声望
撰写一个指南
团队
Baylor, Team 8-3, Whitney Spring 2017 Baylor, Team 8-3, Whitney Spring 2017 的会员
BU-WHITNEY-S17S8G3
5 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 5
总计 220
