跳转到主内容
Chumby One Motherboard Replacement
你所需要的
  1. Chumby One Motherboard Replacement, Chassis: 步骤 1 中的图像 1,1
    • Remove 4 self-adhesive plastic dots covering the screw holes.
  2. Chumby One Motherboard Replacement: 步骤 2 中的图像 1,1
    • Remove the four 2mm screws with a Phillips screwdriver.
  3. Chumby One Motherboard Replacement: 步骤 3 中的图像 1,1
    • Remove the back and bottom cover.
  4. Chumby One Motherboard Replacement: 步骤 4 中的图像 1,1
    • Disconnect the battery connector from the motherboard with a plastic opening tool.
  5. Chumby One Motherboard Replacement: 步骤 5 中的图像 1,1
    • Disconnect the microphone connector from the motherboard with a plastic opening tool.
  6. Chumby One Motherboard Replacement: 步骤 6 中的图像 1,1
    • Remove the display ribbon cable from its socket with a plastic opening tool.
  7. Chumby One Motherboard Replacement: 步骤 7 中的图像 1,1
    • Remove the volume knob from the side of the Chumby One with a plastic opening tool.
  8. Chumby One Motherboard Replacement: 步骤 8 中的图像 1,1
    • Remove the four 6mm screws using a PH000 bit on the inner chassis.
  9. Chumby One Motherboard Replacement: 步骤 9 中的图像 1,1
    • Remove the inner components from the outer shell.
  10. Chumby One Motherboard Replacement, Motherboard: 步骤 10 中的图像 1,1
    • Remove the speaker connector using a plastic spudger.
  11. Chumby One Motherboard Replacement: 步骤 11 中的图像 1,1
    • Remove the Chumby button connector using a plastic spudger.
  12. Chumby One Motherboard Replacement: 步骤 12 中的图像 1,1
    • Remove three 6mm screws using a PH000 bit.
  13. Chumby One Motherboard Replacement: 步骤 13 中的图像 1,1
    • Remove the motherboard by pulling straight away from the housing.
    • Removing the motherboard there are 2 pins and socket connectors that may cause injury.
结论
Jordan Houchins
于03/27/17注册
401 声望
创作了4篇指南
团队
IUPUI, Team S3-G3, Baechle Spring 2017 IUPUI, Team S3-G3, Baechle Spring 2017 的会员
IUPUI-BAECHLE-S17S3G3
4 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 289
