跳转到主内容
Chumby One LCD Screen Replacement
你所需要的
  1. Chumby One LCD Screen Replacement, Chassis: 步骤 1 中的图像 1,1
    • Remove 4 self-adhesive plastic dots covering the screw holes.
  2. Chumby One LCD Screen Replacement: 步骤 2 中的图像 1,1
    • Remove the four 2mm screws with a Phillips screwdriver.
  3. Chumby One LCD Screen Replacement: 步骤 3 中的图像 1,1
    • Remove the back and bottom cover.
  4. Chumby One LCD Screen Replacement: 步骤 4 中的图像 1,1
    • Disconnect the battery connector from the motherboard with a plastic opening tool.
  5. Chumby One LCD Screen Replacement: 步骤 5 中的图像 1,1
    • Disconnect the microphone connector from the motherboard with a plastic opening tool.
  6. Chumby One LCD Screen Replacement: 步骤 6 中的图像 1,1
    • Remove the display ribbon cable from its socket with a plastic opening tool.
  7. Chumby One LCD Screen Replacement: 步骤 7 中的图像 1,1
    • Remove the volume knob from the side of the Chumby One with a plastic opening tool.
  8. Chumby One LCD Screen Replacement: 步骤 8 中的图像 1,1
    • Remove the four 6mm screws using a PH000 bit on the inner chassis.
  9. Chumby One LCD Screen Replacement: 步骤 9 中的图像 1,1
    • Remove the inner components from the outer shell.
  10. Chumby One LCD Screen Replacement, LCD Screen: 步骤 10 中的图像 1,1
    • Remove the four 5.5mm screws with a Phillips PH000 screwdriver bit.
  11. Chumby One LCD Screen Replacement: 步骤 11 中的图像 1,1
    • Remove the metal shield from the front case using a plastic opening tool.
  12. Chumby One LCD Screen Replacement: 步骤 12 中的图像 1,1
    • Remove the LCD screen from the outer case using a plastic opening tool.
结论
Jordan Houchins
于03/27/17注册
401 声望
创作了4篇指南
团队
IUPUI, Team S3-G3, Baechle Spring 2017 IUPUI, Team S3-G3, Baechle Spring 2017 的会员
IUPUI-BAECHLE-S17S3G3
4 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 11
总计 222
