跳转到主内容
Chromo Inc. T2 Motherboard Replacement
你所需要的
  1. Chromo Inc. T2 Motherboard Replacement, Removing the Casing: 步骤 1 中的图像 1,3 Chromo Inc. T2 Motherboard Replacement, Removing the Casing: 步骤 1 中的图像 2,3 Chromo Inc. T2 Motherboard Replacement, Removing the Casing: 步骤 1 中的图像 3,3
    • Place your Plastic Opening Tool between the screen and the case. Slowly move it around the casing while prying in a downward motion to undo the hinges holding the two together and separate the two parts.
  2. Chromo Inc. T2 Motherboard Replacement, Turn it around: 步骤 2 中的图像 1,1
    • After separating the case and screen, turn your screen face down so you can see the internal parts!
  3. Chromo Inc. T2 Motherboard Replacement, Disconnecting Flex Cables: 步骤 3 中的图像 1,2 Chromo Inc. T2 Motherboard Replacement, Disconnecting Flex Cables: 步骤 3 中的图像 2,2
    • Peel back the tape holding the big flex cable in place.
    • Using your plastic opening tool, gently push back the gray connector to free the flex cables and then pull them out.
  4. Chromo Inc. T2 Motherboard Replacement, Disconnecting the Camera: 步骤 4 中的图像 1,2 Chromo Inc. T2 Motherboard Replacement, Disconnecting the Camera: 步骤 4 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Using the small plastic opening tool, gently push the gray connector back to unlock the flex cable.
    • Using a pair of tweezers, gently grasp the flex cable and disconnect it from the connector.
  5. Chromo Inc. T2 Motherboard Replacement: 步骤 5 中的图像 1,2 Chromo Inc. T2 Motherboard Replacement: 步骤 5 中的图像 2,2
    • Using a Phillips #00 Precision Screwdriver, remove the three 3mm screws holding the motherboard.
  6. Chromo Inc. T2 Motherboard Replacement: 步骤 6 中的图像 1,3 Chromo Inc. T2 Motherboard Replacement: 步骤 6 中的图像 2,3 Chromo Inc. T2 Motherboard Replacement: 步骤 6 中的图像 3,3
    • Using your soldering iron, desolder the six wires on the side of the logic board.
    • Note: Remember where these wires go as re-connecting them incorrectly can lead to damaging the device!
    • Soldering Iron gets very hot, take care to not touch anywhere on the soldering iron except for the handle!
  7. Chromo Inc. T2 Motherboard Replacement: 步骤 7 中的图像 1,2 Chromo Inc. T2 Motherboard Replacement: 步骤 7 中的图像 2,2
    • Using your soldering Iron, desolder the grounding cable on the motherboard.
  8. Chromo Inc. T2 Motherboard Replacement: 步骤 8 中的图像 1,1
    • Your motherboard is now ready for replacement!
结论
Ismael DeLuna
于01/21/15注册
637 声望
创作了5篇指南
团队
USF Tampa, Team 15-1, Watkins Winter 2015 USF Tampa, Team 15-1, Watkins Winter 2015 的会员
USFT-WATKINS-W15S15G1
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 13
总计 660
