跳转到主内容
Chromo Inc. T2 Internal Speaker Replacement
你所需要的
  1. Chromo Inc. T2 Internal Speaker Replacement, Removing the Casing: 步骤 1 中的图像 1,3 Chromo Inc. T2 Internal Speaker Replacement, Removing the Casing: 步骤 1 中的图像 2,3 Chromo Inc. T2 Internal Speaker Replacement, Removing the Casing: 步骤 1 中的图像 3,3
    • Using your Plastic Opening Tool, place it in between the screen and the case. Slowly move it around the casing while prying in a downward motion to undo the hinges holding the two together and separate the two parts.
  2. Chromo Inc. T2 Internal Speaker Replacement, Turn it around: 步骤 2 中的图像 1,1
    • After separating the case and screen, turn your screen face down so you can see the internal parts!
  3. Chromo Inc. T2 Internal Speaker Replacement, Removing the Tape: 步骤 3 中的图像 1,3 Chromo Inc. T2 Internal Speaker Replacement, Removing the Tape: 步骤 3 中的图像 2,3 Chromo Inc. T2 Internal Speaker Replacement, Removing the Tape: 步骤 3 中的图像 3,3
    • Remove two strips of tape: One holding down the wires and the other holding down the internal speaker.
  4. Chromo Inc. T2 Internal Speaker Replacement, Desoldering the Wires and Removing the Speaker: 步骤 4 中的图像 1,3 Chromo Inc. T2 Internal Speaker Replacement, Desoldering the Wires and Removing the Speaker: 步骤 4 中的图像 2,3 Chromo Inc. T2 Internal Speaker Replacement, Desoldering the Wires and Removing the Speaker: 步骤 4 中的图像 3,3
    • Using a Soldering Iron, desolder both speaker wires. Once both wires are desoldered, your Internal Speaker is now ready for replacement!
    • Soldering Iron gets very hot, take care to not touch anywhere on the soldering iron except for the handle!
结论
Ismael DeLuna
于01/21/15注册
637 声望
创作了5篇指南
团队
USF Tampa, Team 15-1, Watkins Winter 2015 USF Tampa, Team 15-1, Watkins Winter 2015 的会员
USFT-WATKINS-W15S15G1
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 224
