跳转到主内容
Chromo Inc. T2 Front Facing Camera Replacement
你所需要的
  1. Chromo Inc. T2 Front Facing Camera Replacement, Removing the Casing: 步骤 1 中的图像 1,3 Chromo Inc. T2 Front Facing Camera Replacement, Removing the Casing: 步骤 1 中的图像 2,3 Chromo Inc. T2 Front Facing Camera Replacement, Removing the Casing: 步骤 1 中的图像 3,3
    • Place your Plastic Opening Tool between the screen and the case. Slowly move it around the casing while prying in a downward motion to undo the hinges holding the two together and separate the two parts.
  2. Chromo Inc. T2 Front Facing Camera Replacement, Turn it around: 步骤 2 中的图像 1,1
    • After separating the case and screen, turn your screen face down so you can see the internal parts!
  3. Chromo Inc. T2 Front Facing Camera Replacement, Getting to the camera: 步骤 3 中的图像 1,1
    • Remove the tape that holds the camera in place.
  4. Chromo Inc. T2 Front Facing Camera Replacement, Free up the flex cable: 步骤 4 中的图像 1,1
    • Using the small plastic opening tool, gently push the gray connector back to unlock the flex cable.
  5. Chromo Inc. T2 Front Facing Camera Replacement, Removing the Flex Cable and Camera: 步骤 5 中的图像 1,2 Chromo Inc. T2 Front Facing Camera Replacement, Removing the Flex Cable and Camera: 步骤 5 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Using a pair of tweezers, gently grasp the flex cable and pull it out while using your other hand to keep the camera in place. Once removed, your camera is now free and ready for replacement!
结论
Ismael DeLuna
于01/21/15注册
637 声望
创作了5篇指南
团队
USF Tampa, Team 15-1, Watkins Winter 2015 USF Tampa, Team 15-1, Watkins Winter 2015 的会员
USFT-WATKINS-W15S15G1
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 12
总计 256
