跳转到主内容
Chromo Inc. T2 Battery Replacement
你所需要的
  1. Chromo Inc. T2 Battery Replacement, Removing the Casing: 步骤 1 中的图像 1,3 Chromo Inc. T2 Battery Replacement, Removing the Casing: 步骤 1 中的图像 2,3 Chromo Inc. T2 Battery Replacement, Removing the Casing: 步骤 1 中的图像 3,3
    • Place your Plastic Opening Tool between the screen and the case. Slowly move it around the casing while prying in a downward motion to undo the hinges holding the two together and separate the two parts.
  2. Chromo Inc. T2 Battery Replacement, Turn it around: 步骤 2 中的图像 1,1
    • After separating the case and screen, turn your screen face down so you can see the internal parts!
  3. Chromo Inc. T2 Battery Replacement, Freeing the Battery: 步骤 3 中的图像 1,3 Chromo Inc. T2 Battery Replacement, Freeing the Battery: 步骤 3 中的图像 2,3 Chromo Inc. T2 Battery Replacement, Freeing the Battery: 步骤 3 中的图像 3,3
    • Using the Spudger, going between the battery and screen, pry the battery off from the tablet.
    • Note: This will require a little extra force due to the tape holding down the battery!
  4. Chromo Inc. T2 Battery Replacement, Desoldering the Battery Wires: 步骤 4 中的图像 1,1
    • Using a Soldering Iron, desolder both Battery wires.
    • Soldering Iron gets very hot, take care to not touch anywhere on the soldering iron except for the handle!
  5. Chromo Inc. T2 Battery Replacement, Finished!: 步骤 5 中的图像 1,1
    • Your battery is now ready to be replaced!
结论
2等其他人完成本指南。
Ismael DeLuna
于01/21/15注册
637 声望
创作了5篇指南
团队
USF Tampa, Team 15-1, Watkins Winter 2015 USF Tampa, Team 15-1, Watkins Winter 2015 的会员
USFT-WATKINS-W15S15G1
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 7
总计 1,583
