跳转到主内容
Chromecast Metal Shielding Replacement
你所需要的
  1. Chromecast Metal Shielding Replacement, Case: 步骤 1 中的图像 1,1
    • Place the Google Chromecast face down (with text not showing) on a flat surface.
    • Insert a flat tool just above the micro-USB port to detach the top part of the case from the bottom.
  2. Chromecast Metal Shielding Replacement: 步骤 2 中的图像 1,1
    • Continue prying the top of the case from the bottom toward the HDMI port until the top casing is completely removed.
  3. Chromecast Metal Shielding Replacement: 步骤 3 中的图像 1,1
    • Remove the circuit board, lifting from the HDMI port.
    • The power button may become dislodged.
  4. Chromecast Metal Shielding Replacement: 步骤 4 中的图像 1,1
    • Pry the plastic clamp from the heatsink.
    • Do not pry too hard to avoid breaking the clamp.
  5. Chromecast Metal Shielding Replacement: 步骤 5 中的图像 1,2 Chromecast Metal Shielding Replacement: 步骤 5 中的图像 2,2
    • Insert a plastic opening tool under the heatsink, and pry the heatsink up and out of the case.
    • The adhesive's strength may vary, and force should be applied gently until it becomes dislodged to avoid breaking the device.
  6. Chromecast Metal Shielding Replacement, Metal Shielding: 步骤 6 中的图像 1,1
    • Pry the metal extensions from the HDMI port.
  7. Chromecast Metal Shielding Replacement: 步骤 7 中的图像 1,1
    • Insert the plastic opening tool into the corner next to the metal extensions, prying upward.
  8. Chromecast Metal Shielding Replacement: 步骤 8 中的图像 1,1
    • Pry the metal piece around the metal, extruding it from the internal components.
  9. Chromecast Metal Shielding Replacement: 步骤 9 中的图像 1,1
    • Completely remove the top metal casing to expose the internal components.
  10. Chromecast Metal Shielding Replacement: 步骤 10 中的图像 1,1
    • Pry metal extensions from the HDMI port on the posterior side of the device.
  11. Chromecast Metal Shielding Replacement: 步骤 11 中的图像 1,1
    • Insert the plastic opening tool under the corner to pry off the metal casing from the internal components.
  12. Chromecast Metal Shielding Replacement: 步骤 12 中的图像 1,1
    • Continue prying around the device, removing the metal piece from the internal components.
  13. Chromecast Metal Shielding Replacement: 步骤 13 中的图像 1,1
    • Completely remove the bottom metal piece.
结论
2等其他人完成本指南。
Cameron Heiges
于03/21/18注册
680 声望
创作了3篇指南
团队
IUPUI, Team S5-G6, Baechle Spring 2018 IUPUI, Team S5-G6, Baechle Spring 2018 的会员
IUPUI-BAECHLE-S18S5G6
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 1,624
