跳转到主内容
Chromebook x360 14-da0011dx Wireless Card Replacement
你所需要的
  1. Chromebook x360 14-da0011dx Wireless Card Replacement, Lower Case: 步骤 1 中的图像 1,1
    • Flip the device over with the hinge facing away from you.
    • On the back of the device, remove the two rubber strips on the top and the bottom of the device using a spudger.
  2. Chromebook x360 14-da0011dx Wireless Card Replacement: 步骤 2 中的图像 1,2 Chromebook x360 14-da0011dx Wireless Card Replacement: 步骤 2 中的图像 2,2
    • Remove the seven 8.0 mm screws located under the two rubber pads and the screws along the back of the device using a Phillips #1 screwdriver.
  3. Chromebook x360 14-da0011dx Wireless Card Replacement: 步骤 3 中的图像 1,3 Chromebook x360 14-da0011dx Wireless Card Replacement: 步骤 3 中的图像 2,3 Chromebook x360 14-da0011dx Wireless Card Replacement: 步骤 3 中的图像 3,3
    • Use a spudger to gently pry the edges of the back cover off the device. Slowly work all the way around the device until the panel comes loose.
  4. Chromebook x360 14-da0011dx Wireless Card Replacement, Wireless card: 步骤 4 中的图像 1,1
    • Remove the plastic protector from the top of the wires plugged into the wireless card.
  5. Chromebook x360 14-da0011dx Wireless Card Replacement: 步骤 5 中的图像 1,1
    • Remove the single 3 mm screw holding down the wireless card with the Phillips #1 screwdriver.
  6. Chromebook x360 14-da0011dx Wireless Card Replacement: 步骤 6 中的图像 1,2 Chromebook x360 14-da0011dx Wireless Card Replacement: 步骤 6 中的图像 2,2
    • Disconnect the antenna cables leading into the wireless card.
    • Slide the wireless card out of its port and lift it out of the device.
    • The cables are numbered with their corresponding port. Be careful not to damage the connections when reassembling during this step.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 23
总计 144
