跳转到主内容
Chromebook x360 14-da0011dx Motherboard Replacement
你所需要的
  1. Chromebook x360 14-da0011dx Motherboard Replacement, Lower Case: 步骤 1 中的图像 1,1
    • Flip the device over with the hinge facing away from you.
    • On the back of the device, remove the two rubber strips on the top and the bottom of the device using a spudger.
  2. Chromebook x360 14-da0011dx Motherboard Replacement: 步骤 2 中的图像 1,2 Chromebook x360 14-da0011dx Motherboard Replacement: 步骤 2 中的图像 2,2
    • Remove the seven 8.0 mm screws located under the two rubber pads and the screws along the back of the device using a Phillips #1 screwdriver.
  3. Chromebook x360 14-da0011dx Motherboard Replacement: 步骤 3 中的图像 1,3 Chromebook x360 14-da0011dx Motherboard Replacement: 步骤 3 中的图像 2,3 Chromebook x360 14-da0011dx Motherboard Replacement: 步骤 3 中的图像 3,3
    • Use a spudger to gently pry the edges of the back cover off the device. Slowly work all the way around the device until the panel comes loose.
  4. Chromebook x360 14-da0011dx Motherboard Replacement, Battery: 步骤 4 中的图像 1,2 Chromebook x360 14-da0011dx Motherboard Replacement, Battery: 步骤 4 中的图像 2,2
    • Remove the cable attached to the battery.
  5. Chromebook x360 14-da0011dx Motherboard Replacement: 步骤 5 中的图像 1,2 Chromebook x360 14-da0011dx Motherboard Replacement: 步骤 5 中的图像 2,2
    • Remove the five 3.0 mm screws holding the battery in place using the Phillips #1 screwdriver.
  6. Chromebook x360 14-da0011dx Motherboard Replacement: 步骤 6 中的图像 1,1
    • Lift the battery out of the chassis.
  7. Chromebook x360 14-da0011dx Motherboard Replacement, Fan: 步骤 7 中的图像 1,1
    • Remove the two 3.0 mm Phillips #1 screws holding the fan in place.
  8. Chromebook x360 14-da0011dx Motherboard Replacement: 步骤 8 中的图像 1,2 Chromebook x360 14-da0011dx Motherboard Replacement: 步骤 8 中的图像 2,2
    • Disconnect the fan cable from the motherboard.
    • Carefully remove the fan from the computer.
    • Be careful when removing the fan, as it sits under one of the CPU heat pipes and tucks under the ribbon cable that runs to the I/O board.
  9. Chromebook x360 14-da0011dx Motherboard Replacement, Motherboard: 步骤 9 中的图像 1,3 Chromebook x360 14-da0011dx Motherboard Replacement, Motherboard: 步骤 9 中的图像 2,3 Chromebook x360 14-da0011dx Motherboard Replacement, Motherboard: 步骤 9 中的图像 3,3
    • Lift the ZIF connector locking flaps, then remove the ribbon cables.
    • There are several small connections for the ribbon cables. Exercise extreme caution when disconnecting the cables.
    • One ribbon cable is on the underside of the motherboard and will be removed later.
  10. Chromebook x360 14-da0011dx Motherboard Replacement: 步骤 10 中的图像 1,1
    • Remove the three 3.0 mm Phillips #1 screws holding the motherboard in place.
  11. Chromebook x360 14-da0011dx Motherboard Replacement: 步骤 11 中的图像 1,3 Chromebook x360 14-da0011dx Motherboard Replacement: 步骤 11 中的图像 2,3 Chromebook x360 14-da0011dx Motherboard Replacement: 步骤 11 中的图像 3,3
    • Disconnect the cables attached to the Wi-Fi card and motherboard along the top edge.
    • The leftmost connector is a ribbon-style connector with a metal locking bar that must be unlatched.
  12. Chromebook x360 14-da0011dx Motherboard Replacement: 步骤 12 中的图像 1,3 Chromebook x360 14-da0011dx Motherboard Replacement: 步骤 12 中的图像 2,3 Chromebook x360 14-da0011dx Motherboard Replacement: 步骤 12 中的图像 3,3
    • Use a spudger to remove the tape and plastic shielding that secure the wires.
  13. Chromebook x360 14-da0011dx Motherboard Replacement: 步骤 13 中的图像 1,1
    • Gently lift the motherboard until it is loose.
    • Disconnect the ribbon cable attached to the underside of the motherboard.
    • The locking flap on this ribbon cable must be flipped down to unlock.
  14. Chromebook x360 14-da0011dx Motherboard Replacement: 步骤 14 中的图像 1,1
    • Lift the motherboard from the device.
    • Removal of the heat pipes may be necessary for replacement if your new replacement motherboard doesn't have one installed.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 11
过去 30 天: 34
总计 243
