跳转到主内容
Chromebook x360 14-da0011dx Fan Replacement
你所需要的
  1. Chromebook x360 14-da0011dx Fan Replacement, Lower Case: 步骤 1 中的图像 1,1
    • Flip the device over with the hinge facing away from you.
    • On the back of the device, remove the two rubber strips on the top and the bottom of the device using a spudger.
  2. Chromebook x360 14-da0011dx Fan Replacement: 步骤 2 中的图像 1,2 Chromebook x360 14-da0011dx Fan Replacement: 步骤 2 中的图像 2,2
    • Remove the seven 8.0 mm screws located under the two rubber pads and the screws along the back of the device using a Phillips #1 screwdriver.
  3. Chromebook x360 14-da0011dx Fan Replacement: 步骤 3 中的图像 1,3 Chromebook x360 14-da0011dx Fan Replacement: 步骤 3 中的图像 2,3 Chromebook x360 14-da0011dx Fan Replacement: 步骤 3 中的图像 3,3
    • Use a spudger to gently pry the edges of the back cover off the device. Slowly work all the way around the device until the panel comes loose.
  4. Chromebook x360 14-da0011dx Fan Replacement, Battery: 步骤 4 中的图像 1,2 Chromebook x360 14-da0011dx Fan Replacement, Battery: 步骤 4 中的图像 2,2
    • Remove the cable attached to the battery.
  5. Chromebook x360 14-da0011dx Fan Replacement: 步骤 5 中的图像 1,2 Chromebook x360 14-da0011dx Fan Replacement: 步骤 5 中的图像 2,2
    • Remove the five 3.0 mm screws holding the battery in place using the Phillips #1 screwdriver.
  6. Chromebook x360 14-da0011dx Fan Replacement: 步骤 6 中的图像 1,1
    • Lift the battery out of the chassis.
  7. Chromebook x360 14-da0011dx Fan Replacement, Fan: 步骤 7 中的图像 1,1
    • Remove the two 3.0 mm Phillips #1 screws holding the fan in place.
  8. Chromebook x360 14-da0011dx Fan Replacement: 步骤 8 中的图像 1,2 Chromebook x360 14-da0011dx Fan Replacement: 步骤 8 中的图像 2,2
    • Disconnect the fan cable from the motherboard.
    • Carefully remove the fan from the computer.
    • Be careful when removing the fan, as it sits under one of the CPU heat pipes and tucks under the ribbon cable that runs to the I/O board.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 31
总计 169
