跳转到主内容
Chromebook Pixel (2013) Battery Replacement
你所需要的
  1. Chromebook Pixel (2013) Battery Replacement, Remove the rubber pads: 步骤 1 中的图像 1,2 Chromebook Pixel (2013) Battery Replacement, Remove the rubber pads: 步骤 1 中的图像 2,2
    • Flip your Chromebook Pixel over onto its back
    • Using a flat edge screwdriver, gently pull up to remove the rubber pads from the laptop to reveal the screws
  2. Chromebook Pixel (2013) Battery Replacement, Removing the bottom panel: 步骤 2 中的图像 1,3 Chromebook Pixel (2013) Battery Replacement, Removing the bottom panel: 步骤 2 中的图像 2,3 Chromebook Pixel (2013) Battery Replacement, Removing the bottom panel: 步骤 2 中的图像 3,3
    • Using a small Philips screwdriver, remove the four screws under the pads
    • Using a spudger (or another flat but slightly blunt object), gently pry the laptop open
    • You may find it helpful to start with a smaller (skinnier) head and work your way up to a larger size
  3. Chromebook Pixel (2013) Battery Replacement, Pop it open: 步骤 3 中的图像 1,2 Chromebook Pixel (2013) Battery Replacement, Pop it open: 步骤 3 中的图像 2,2
    • Gently pull up from the front of the laptop and open it up like a clamshell
  4. Chromebook Pixel (2013) Battery Replacement, Remove the write protect screw (IF APPLICABLE): 步骤 4 中的图像 1,2 Chromebook Pixel (2013) Battery Replacement, Remove the write protect screw (IF APPLICABLE): 步骤 4 中的图像 2,2
    • Locate the write protect screw
    • Remove it and you can begin flashing your BIOS!
  5. Chromebook Pixel (2013) Battery Replacement, Remove the bottom cover: 步骤 5 中的图像 1,1
    • You should have your Chromebook Pixel flipped over and the bottom cover removed at this point
  6. Chromebook Pixel (2013) Battery Replacement, Release the battery: 步骤 6 中的图像 1,1
    • Remove the screws holding the battery in place.
  7. Chromebook Pixel (2013) Battery Replacement, Unplug the battery: 步骤 7 中的图像 1,2 Chromebook Pixel (2013) Battery Replacement, Unplug the battery: 步骤 7 中的图像 2,2
    • Using a splunger or your finger and a gentle pull, unplug the battery from the Pixel logic board
    • Pull the battery toward you to remove it
  8. Chromebook Pixel (2013) Battery Replacement, Examine the new battery: 步骤 8 中的图像 1,1
    • Make sure that the wattage and voltage matches the values of the old battery
  9. Chromebook Pixel (2013) Battery Replacement, Install the new battery: 步骤 9 中的图像 1,2 Chromebook Pixel (2013) Battery Replacement, Install the new battery: 步骤 9 中的图像 2,2
    • Follow these steps in reverse and turn on the Pixel.
    • If the old battery was failing, will have to reset the system time when you log back into Chrome OS or your installed Operating System
结论
8等其他人完成本指南。
Kevin Fessler
于04/16/16注册
1,773 声望
创作了4篇指南
2条评论
You can now find these batteries on Amazon too- just search for the same part number GP-S22-000000-0100
riansanderson - 回复
Hello could someone help
Where would i get a replacement battery from ? having trouble locating one .
Thanks in advance nick
Nick Harrisson - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 25
总计 7,131
