跳转到主内容
Chromebook 14-x015wm Keyboard Replacement
你所需要的
  1. Chromebook 14-x015wm Keyboard Replacement, Keyboard: 步骤 1 中的图像 1,2 Chromebook 14-x015wm Keyboard Replacement, Keyboard: 步骤 1 中的图像 2,2
    • Remove the small rubber circles over all four corners on the bottom of the chromebook.
    • Remove the three small additional rubber covers along edge of computer with hinge.
    • Unscrew all the screws on the bottom of the laptop using a Phillips #00 screwdriver.
    • Make sure to keep track of the screws for reassembly.
  2. Chromebook 14-x015wm Keyboard Replacement: 步骤 2 中的图像 1,1
    • Flip the laptop back over to the front and open it so that the keyboard is visible.
    • Use the iFixit opening tool to pry off the keyboard by placing the tool in-between the keyboard and the case. Move the tool around all sides until the keyboard separates.
    • The keyboard will likely be difficult to remove.
    • Be careful to avoid pulling on the ribbons that connect the keyboard to the internal components in order to prevent damage.
  3. Chromebook 14-x015wm Keyboard Replacement: 步骤 3 中的图像 1,1
    • Carefully unclip the ribbons under the keyboard to disconnect the keyboard.
    • Replace the keyboard and connect the ribbons to the new keyboard.
    • Press the computer case shut and replace the screws and rubber pads.
终点
2等其他人完成本指南。
团队
UMass Dartmouth, Team S1-G2, Isaacson Fall 2017 UMass Dartmouth, Team S1-G2, Isaacson Fall 2017 的会员
UMASSD-ISAACSON-F17S1G2
2 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 7
总计 450
