跳转到主内容
Chromebook 14-x015wm Key Replacement
你所需要的
  1. Chromebook 14-x015wm Key Replacement, Key: 步骤 1 中的图像 1,1
    • Take a flathead screw driver and place it right under the key. Very gently pry it up. If it doesn't come off right away, try and loosen it by using the flathead on all four sides and wiggle it.
  2. Chromebook 14-x015wm Key Replacement: 步骤 2 中的图像 1,1
    • Once the key is off, all you have to do to put a new key on is center it exactly how the original one was, and push down.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 222
