跳转到主内容
HP Chromebook 14-x015wm Battery Replacement
你所需要的
  1. HP Chromebook 14-x015wm Battery Replacement, Battery: 步骤 1 中的图像 1,2 HP Chromebook 14-x015wm Battery Replacement, Battery: 步骤 1 中的图像 2,2
    • Turn the Chromebook upside down so that the bottom is facing upwards.
    • Remove the small rubber circles from all four corners.
    • Remove the other three rubber pads from the bottom
    • Proceed to unscrew all the screws.
    • Keep the screws on a magnetic mat or in a secure location and keep track of which screws went where.
  2. HP Chromebook 14-x015wm Battery Replacement: 步骤 2 中的图像 1,1
    • Flip the laptop back over and open it so that the keyboard is revealed to you.
    • Use a plastic opening tool to pry off the keyboard. It's slightly difficult to get off, but go evenly around all four sides until it pops out.
    • Be careful of the ribbons underneath that connect the keyboard to the internal components.
  3. HP Chromebook 14-x015wm Battery Replacement: 步骤 3 中的图像 1,2 HP Chromebook 14-x015wm Battery Replacement: 步骤 3 中的图像 2,2
    • The long, flat, black component that takes up the majority of the space is the battery.
    • All you are required to do is unscrew the screws attached to the battery and then gently remove the battery from the Chromebook.
    • Make sure to keep track of where the screws came from.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 25
总计 1,359
