跳转到主内容
Chevy 305 Engine Rear Main Seal Replacement
你所需要的
  1. Chevy 305 Engine Rear Main Seal Replacement, Rear Main Seal: 步骤 1 中的图像 1,2 Chevy 305 Engine Rear Main Seal Replacement, Rear Main Seal: 步骤 1 中的图像 2,2
    • Remove the 18 bolts holding the oil pan in place using the 3⁄8 and 1⁄2 sockets, 6 inch extension and 3⁄8 ratchet.
    • Fourteen 3/8 bolts around the perimeter and four 1/2 bolts on each corner.
    • Lift the oil pan up and forward so the oil pump pick up will clear the baffle.
    • Do not remove the oil pan gasket yet.
  2. Chevy 305 Engine Rear Main Seal Replacement: 步骤 2 中的图像 1,3 Chevy 305 Engine Rear Main Seal Replacement: 步骤 2 中的图像 2,3 Chevy 305 Engine Rear Main Seal Replacement: 步骤 2 中的图像 3,3
    • Remove the single 9/16 bolt holding the oil pump in place and pull straight up from the base of the oil pump to remove.
    • Using a rubber mallet to break loose, gently tap on the side of the base of the pump indicated by the arrow. DO NOT HIT THE TOP OF THE PICK UP TUBE AND SCREEN. This can potentially damage the pick up tube or screen.
  3. Chevy 305 Engine Rear Main Seal Replacement: 步骤 3 中的图像 1,2 Chevy 305 Engine Rear Main Seal Replacement: 步骤 3 中的图像 2,2
    • Remove the six 11/16 flywheel bolts using the 11/16 socket.
    • The breaker bar may be needed to break these bolts loose
    • This provides more room to access the rear main cap.
  4. Chevy 305 Engine Rear Main Seal Replacement: 步骤 4 中的图像 1,3 Chevy 305 Engine Rear Main Seal Replacement: 步骤 4 中的图像 2,3 Chevy 305 Engine Rear Main Seal Replacement: 步骤 4 中的图像 3,3
    • Remove the two 5/8 rear main cap bolts. Gently tap the side of cap with a rubber mallet if needed to break free.
    • Remove the rear main seal. The upper half of the seal can easily be removed by hand.
    • Loop the new bottom half of the seal through the slot indicated in picture.
    • Needle nose pliers may make this easier but be cautious not to handle the new seal too aggressively so you do not damage it .
    • Put the rear main cap back and torque to specs (65 ft.-lbs.) followed by the oil pump and torque to specs (60-70 ft.-lbs.)
结论
To reassemble, follow these instructions in reverse order following manufacture recommended torque specs and sequences.
另外一个人完成了本指南。
Matt Clark
于10/30/19注册
152 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 28
过去 30 天: 148
总计 8,525
