跳转到主内容
Chefman RJ38-V2-35 Power Cord Replacement
你所需要的
  1. Chefman RJ38-V2-35 Power Cord Replacement, Power Cord: 步骤 1 中的图像 1,1
    • Please be sure that the device is unplugged and remove the frying basket from the device.
    • Check the power cord for frays or cracks
  2. Chefman RJ38-V2-35 Power Cord Replacement: 步骤 2 中的图像 1,2 Chefman RJ38-V2-35 Power Cord Replacement: 步骤 2 中的图像 2,2
    • If the cord appears to be fine, orient your device upside down so that the temperature knob is on the bottom and the power cord area is facing you.
    • Place your hand firmly on the device to prevent slippage.
    • Using the Phillips #1 screwdriver, remove the two 4 mm screws found at each corner of the bottom panel.
  3. Chefman RJ38-V2-35 Power Cord Replacement: 步骤 3 中的图像 1,2 Chefman RJ38-V2-35 Power Cord Replacement: 步骤 3 中的图像 2,2
    • After removing the two screws on the bottom, remove the four 6mm screws located on the white tabs that are securing the power cord.
    • Once the white tabs come off, the power cord will be more visible, the white wire is connected with the blue wire, while the black wire is connected with the red wire.
  4. Chefman RJ38-V2-35 Power Cord Replacement: 步骤 4 中的图像 1,2 Chefman RJ38-V2-35 Power Cord Replacement: 步骤 4 中的图像 2,2
    • Use a pair of scissor, cut off any secure wire attachments, such as the white capsule.
    • The wire will come apart and you can now separate the power cord from the device’s wires.
    • The red and blue wires of the device will show it’s aluminum strips, this is what connect to the replacement wire.
结论
3等其他人完成本指南。
An L Duong
于10/17/18注册
295 声望
撰写一个指南
团队
UW Tacoma, Team S1-G4, Rose Fall 2018 UW Tacoma, Team S1-G4, Rose Fall 2018 的会员
UWT-ROSE-F18S1G4
4 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 7
过去 7 天: 28
过去 30 天: 116
总计 6,774
