跳转到主内容
Chefman RJ-38-V2-35 Fryer Basket Replacement
你所需要的
  1. Chefman RJ-38-V2-35 Fryer Basket Replacement, Fryer Basket: 步骤 1 中的图像 1,1
    • Make sure the air fryer is unplugged and the basket is cool enough to handle.
    • Remove the basket from the air fryer.
  2. Chefman RJ-38-V2-35 Fryer Basket Replacement: 步骤 2 中的图像 1,1
    • Place the fryer basket on a flat surface.
    • Using the Phillips #1 screwdriver, remove four 5mm screws on the inside of the fryer basket (left two screws shown).
  3. Chefman RJ-38-V2-35 Fryer Basket Replacement: 步骤 3 中的图像 1,1
    • Separate the handle from the basket.
结论
另外一个人完成了本指南。
Benn Rutledge
于10/17/18注册
127 声望
撰写一个指南
团队
UW Tacoma, Team S1-G4, Rose Fall 2018 UW Tacoma, Team S1-G4, Rose Fall 2018 的会员
UWT-ROSE-F18S1G4
4 名成员
创作了3篇指南
4条评论
I need the plate inside the basket. The coating is coming off, Is it safe to use?
Eileen Morrison - 回复
Where can I buy only the basket or just the plate? I need replacement but don’t seem to find the parts…
Eszter Stranszky - 回复
I need the plate inside the basket. Coating is coming off.
Sandy Mentzer - 回复
Where can I buy replacement rubber feet for the fryer basket plate? Mine came off and went down the disposal!! Are they required for proper heating and frying??
Betty Johnson - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 11
过去 30 天: 52
总计 3,545
