跳转到主内容
Chef's Choice M115 Power Cord Replacement
你所需要的
  1. Chef's Choice M115 Power Cord Replacement, Case: 步骤 1 中的图像 1,2 Chef's Choice M115 Power Cord Replacement, Case: 步骤 1 中的图像 2,2
    • Remove the two rubber feet on the motor side of the device.
    • Remove the five Phillips screws from the bottom of the case.
    • These screws are recessed deep in the device, so a long, thin screwdriver is required.
  2. Chef's Choice M115 Power Cord Replacement: 步骤 2 中的图像 1,1
    • Remove the two hex-cap screws on the bottom using a pair of pliers.
  3. Chef's Choice M115 Power Cord Replacement: 步骤 3 中的图像 1,1
    • Carefully flip the device right-side-up while grasping the top and bottom pieces.
    • The white cover should lift off with no resistance. If it does not, ensure all screws were removed in previous step.
  4. Chef's Choice M115 Power Cord Replacement: 步骤 4 中的图像 1,1
    • Remove the sharpener guard by gently pulling up on it.
    • If the sharpener guard does not come off easily, ensure all screws were removed in step 1.
  5. Chef's Choice M115 Power Cord Replacement, Power Cord: 步骤 5 中的图像 1,2 Chef's Choice M115 Power Cord Replacement, Power Cord: 步骤 5 中的图像 2,2
    • Carefully lift the entire motor assembly out of the case.
  6. Chef's Choice M115 Power Cord Replacement: 步骤 6 中的图像 1,1
    • Remove the spade connectors from the switch by pulling only on the connector, not the wire.
    • These should come off without tools, but will require a fair bit of force. Mark each wire with tape if you are unsure of the wiring layout of the device.
  7. Chef's Choice M115 Power Cord Replacement: 步骤 7 中的图像 1,1
    • Disconnect the spade connector on the motor by pulling only on the connector, not the cord.
结论
To reassemble your device, follow these instructions in reverse order. Take care to ensure the power connections are connected back to their original location.
另外一个人完成了本指南。
团队
IUPUI, Team 3-3, Harley Fall 2015 IUPUI, Team 3-3, Harley Fall 2015 的会员
IUPUI-HARLEY-F15S3G3
5 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 18
总计 525
