跳转到主内容
Charge 3 Disassembly
你所需要的
  1. Charge 3 Disassembly, Strap Connectors: 步骤 1 中的图像 1,3 Charge 3 Disassembly, Strap Connectors: 步骤 1 中的图像 2,3 Charge 3 Disassembly, Strap Connectors: 步骤 1 中的图像 3,3
    • Remove both T3 screws
    • Slide off the plastic piece by lifting out and then up
    • Slide plastic and spring assembly off the rail
  2. Charge 3 Disassembly, Display: 步骤 2 中的图像 1,3 Charge 3 Disassembly, Display: 步骤 2 中的图像 2,3 Charge 3 Disassembly, Display: 步骤 2 中的图像 3,3
    • Heat the glass screen with a blowdryer to soften the adhesives
    • Start the next step on the opposite side of the Fitbit wording below the glass. This is due to the display cables being located there
    • Insert a razor blade between the glass and the body
    • Keep going around the rim of the display until loose
  3. Charge 3 Disassembly, Cable Warning: 步骤 3 中的图像 1,1
    • This is how close those cables get to the edge underneath the Fitbit wording so be careful
  4. Charge 3 Disassembly, Battery: 步骤 4 中的图像 1,3 Charge 3 Disassembly, Battery: 步骤 4 中的图像 2,3 Charge 3 Disassembly, Battery: 步骤 4 中的图像 3,3
    • Lift display up gently
    • The battery is attached with a little bit of adhesive so lift gently
    • Remove battery connector
  5. Charge 3 Disassembly, Vibrator Shield: 步骤 5 中的图像 1,2 Charge 3 Disassembly, Vibrator Shield: 步骤 5 中的图像 2,2
    • Remove both T2 screws
    • Liftoff metal shield
  6. Charge 3 Disassembly, Main Shield: 步骤 6 中的图像 1,3 Charge 3 Disassembly, Main Shield: 步骤 6 中的图像 2,3 Charge 3 Disassembly, Main Shield: 步骤 6 中的图像 3,3
    • Remove two T2 screws
    • Remove T3 screw
  7. Charge 3 Disassembly, Display Connectors: 步骤 7 中的图像 1,3 Charge 3 Disassembly, Display Connectors: 步骤 7 中的图像 2,3 Charge 3 Disassembly, Display Connectors: 步骤 7 中的图像 3,3
    • Liftoff both display connectors
  8. Charge 3 Disassembly, Disconnect Connectors and Altimeter: 步骤 8 中的图像 1,2 Charge 3 Disassembly, Disconnect Connectors and Altimeter: 步骤 8 中的图像 2,2
    • Disconnect vibrator motor
    • Disconnect heartrate and charging connector
    • Remove altimeter
  9. Charge 3 Disassembly, Side Button and Vibrator: 步骤 9 中的图像 1,3 Charge 3 Disassembly, Side Button and Vibrator: 步骤 9 中的图像 2,3 Charge 3 Disassembly, Side Button and Vibrator: 步骤 9 中的图像 3,3
    • Remove button assembly from case
    • Remove vibrator motor
    • Has a slight bit of adhesive and is magnetic to the case
  10. Charge 3 Disassembly, Motherboard: 步骤 10 中的图像 1,2 Charge 3 Disassembly, Motherboard: 步骤 10 中的图像 2,2
    • Remove motherboard
    • It seems as if the heart rate sensor and charging pins are molded into the case, and I was not able to remove them
终点
2等其他人完成本指南。
ShellingRook27
于08/21/19注册
1,694 声望
创作了7篇指南
团队
Repair For You Repair For You 的会员
Business
1 名成员
创作了11篇指南
12条评论
The tear down pictures are great, but in my Charge 3 I needed a T-1 and a T-2 driver
Julien Baldwin - 回复
Same, my ifixit pro kit only had a driver for the external screws and did not come with a small enough driver to remove the screws inside the charge 3 unit. I'll need to get the smaller bit from a different kit.
Brian Hall -
Which step in the teardown guide needed the T1 driver?
ShellingRook27 -
Great job on this tear-down. Thank you, it really helped in my screen replacement.
AndyZ - 回复
This tear down was very easy to follow. The heart rate monitor was also sealed in with some adhesive for me too but a little heat gun took it right off. I had suspected water leaked in and that in fact was the culprit after inspecting the connection. corrosion all around the HR monitor.
Nick Herbert - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 47
过去 30 天: 193
总计 9,026
