跳转到主内容
Char-Broil Grill Burner Replacement
你所需要的
  1. Char-Broil Grill Burner Replacement, Propane Heating Element: 步骤 1 中的图像 1,1
    • This is an exterior shot of the camping stove.
    • Make sure that you're in a well lit area with towels under the stove to catch any dislodged residue.
  2. Char-Broil Grill Burner Replacement: 步骤 2 中的图像 1,2 Char-Broil Grill Burner Replacement: 步骤 2 中的图像 2,2
    • Remove the lid by pulling straight up on its attached handle.
    • Next remove the top grill grate.
    • Grab one side of the grate.
    • Pull up on that side till you can get your hand under the edge.
    • Using both hands fully remove the grate.
  3. Char-Broil Grill Burner Replacement: 步骤 3 中的图像 1,1
    • Remove the heat distribution plate.
    • Place a hand on either side of the heat distribution plate and pull up.
    • The plate should pull straight out of the grill.
  4. Char-Broil Grill Burner Replacement: 步骤 4 中的图像 1,2 Char-Broil Grill Burner Replacement: 步骤 4 中的图像 2,2
    • Turn the stove on its side so that the bottom is easily accessible.
    • There is a single Phillips Head screw to remove in the center of the stove's bottom.
    • Fully remove this screw to detach the heating element from the main stove body.
  5. Char-Broil Grill Burner Replacement: 步骤 5 中的图像 1,1
    • Turn the stove back onto its legs after removing the bottom screw holding it.
  6. Char-Broil Grill Burner Replacement: 步骤 6 中的图像 1,3 Char-Broil Grill Burner Replacement: 步骤 6 中的图像 2,3 Char-Broil Grill Burner Replacement: 步骤 6 中的图像 3,3
    • Before you can remove the heating element full you need to unscrew the propane vale on the exterior of the stove.
    • Pull up on the heating element, it should be free floating.
    • After the propane valve is unscrewed lift the old heating element out of the stove and replace it with the new part.
结论
2等其他人完成本指南。
Dan
于10/01/17注册
155 声望
撰写一个指南
团队
Michigan Tech, Team S5-G1, Galliah Fall 2017 Michigan Tech, Team S5-G1, Galliah Fall 2017 的会员
MTU-GALLIAH-F17S5G1
3 名成员
创作了2篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 36
总计 709
