跳转到主内容
Change Battery Remote Control Ford Focus MK3 Battery CR2032 Replacement
你所需要的
  1. Change Battery Remote Control Ford Focus MK3  Battery CR2032 Replacement, Battery CR2032: 步骤 1 中的图像 1,1
    • To open the remote control you need a circlip caliper (in german: Seegerringzange ;).
    • The forks of the tool are moving away from each other, when you pull the handles together
  2. Change Battery Remote Control Ford Focus MK3  Battery CR2032 Replacement: 步骤 2 中的图像 1,1
    • Place the tool in the indentation.
    • The forks moving direction has to be perpendicular to the gap of the case .
    • prie one side open then do the same on the other side
  3. Change Battery Remote Control Ford Focus MK3  Battery CR2032 Replacement: 步骤 3 中的图像 1,1
    • Remove the spent battery with the nonconductive spudger tool
  4. Change Battery Remote Control Ford Focus MK3  Battery CR2032 Replacement: 步骤 4 中的图像 1,1
    • Place the new battery in the mounting
    • Check Polarity! Negative pole is facing you.
    • Carefully put the case together
    • Cover old battery with duct tape and take care of the disposal.
    • Be happy an drive safely, because you're done!
结论
Michael
于10/03/17注册
157 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 17
总计 774
