跳转到主内容
Cen-Tech Seven Function Digital Multimeter Circuit Board Replacement
你所需要的
  1. Cen-Tech Seven Function Digital Multimeter Circuit Board Replacement, Position Device: 步骤 1 中的图像 1,1
    • Place the meter face down, and the back panel and screws can be seen.
  2. Cen-Tech Seven Function Digital Multimeter Circuit Board Replacement, Remove Back Panel Screws: 步骤 2 中的图像 1,2 Cen-Tech Seven Function Digital Multimeter Circuit Board Replacement, Remove Back Panel Screws: 步骤 2 中的图像 2,2
    • Unscrew the two 9mm screws on the back panel using a #0 Phillips screwdriver.
  3. Cen-Tech Seven Function Digital Multimeter Circuit Board Replacement, Remove Back Panel: 步骤 3 中的图像 1,1
    • Remove the back panel of the device by lifting upward.
    • Remove the battery from the meter before continuing.
  4. Cen-Tech Seven Function Digital Multimeter Circuit Board Replacement, Unscrew Motherboard: 步骤 4 中的图像 1,2 Cen-Tech Seven Function Digital Multimeter Circuit Board Replacement, Unscrew Motherboard: 步骤 4 中的图像 2,2
    • Remove the four 7mm Phillips screws holding the circuit board in place.
  5. Cen-Tech Seven Function Digital Multimeter Circuit Board Replacement, Remove Motherboard: 步骤 5 中的图像 1,1
    • Gently lift the circuit board away from the device casing.
    • Remove the battery after removing the back cover to reduce the chances of short-circuiting the circuit board.
结论
6等其他人完成本指南。
Anna Kihm
于10/13/14注册
956 声望
创作了5篇指南
团队
Clemson, Team 2-4, Benson Fall 2014 Clemson, Team 2-4, Benson Fall 2014 的会员
CLEM-BENSON-F14S2G4
4 名成员
创作了6篇指南
1指南评论
What is the little dial on the circuit board on the upper right that has numbers 1 through 3 on it and it can be adjusted thank you
Thomas Clawson - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 15
总计 2,857
