跳转到主内容
Cen-Tech Seven Function Digital Multimeter Buzzer Replacement
你所需要的
  1. Cen-Tech Seven Function Digital Multimeter Buzzer Replacement, Adding buzzer: 步骤 1 中的图像 1,3 Cen-Tech Seven Function Digital Multimeter Buzzer Replacement, Adding buzzer: 步骤 1 中的图像 2,3 Cen-Tech Seven Function Digital Multimeter Buzzer Replacement, Adding buzzer: 步骤 1 中的图像 3,3
    • To open you multimeter take off the screws that are circled in the first image
    • The screws are very important make sure to keep them safe and not to loose them
  2. Cen-Tech Seven Function Digital Multimeter Buzzer Replacement: 步骤 2 中的图像 1,2 Cen-Tech Seven Function Digital Multimeter Buzzer Replacement: 步骤 2 中的图像 2,2
    • The red and black arrows point to the positive or red and negative or black for the power of the 2 volt buzzer
    • Use a multimeter and make sure that there really is voltage coming out of there
结论
2等其他人完成本指南。
Busy Bee
于06/20/21注册
139 声望
撰写一个指南
1指南评论
Your red arrow is really obscure its hard to tell what it's pointing to exactly. Btw thanks so much for this I've been using mine for years without a beeper, finally someone figured it out and posted their modification.
lilthumper98 - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 20
总计 826
