跳转到主内容
Ceiva LF2003 Main Circuit Board Replacement
你所需要的
  1. Ceiva LF2003 Main Circuit Board Replacement, Exterior Frame and Matting: 步骤 1 中的图像 1,1
    • Lay the device on its back, and rotate so the base is facing away from you.
  2. Ceiva LF2003 Main Circuit Board Replacement: 步骤 2 中的图像 1,1
    • Grip the frame with your fingers under the edge of the frame, and thumbs pushing down on the front of the device.
  3. Ceiva LF2003 Main Circuit Board Replacement: 步骤 3 中的图像 1,1
    • Lift up the frame with your fingers and push down the rest of the device with your thumbs.
  4. Ceiva LF2003 Main Circuit Board Replacement: 步骤 4 中的图像 1,1
    • Remove the frame and matte from the device.
  5. Ceiva LF2003 Main Circuit Board Replacement, Internal Plastic Screen Frame: 步骤 5 中的图像 1,1
    • Remove the four 7mm Torx T6 screws.
  6. Ceiva LF2003 Main Circuit Board Replacement: 步骤 6 中的图像 1,2 Ceiva LF2003 Main Circuit Board Replacement: 步骤 6 中的图像 2,2
    • Using the plastic opening tool or your fingers, lift up the frame from any edge.
    • Remove the frame from the device.
  7. Ceiva LF2003 Main Circuit Board Replacement, Display: 步骤 7 中的图像 1,3 Ceiva LF2003 Main Circuit Board Replacement, Display: 步骤 7 中的图像 2,3 Ceiva LF2003 Main Circuit Board Replacement, Display: 步骤 7 中的图像 3,3
    • Unplug the cable connecting the display to the power supply using the flat end of the spudger to pry the connector away from the circuit board.
    • Alternate applying pressure to the left and right side of the connector to ensure that it does not break.
  8. Ceiva LF2003 Main Circuit Board Replacement: 步骤 8 中的图像 1,1
  9. Ceiva LF2003 Main Circuit Board Replacement: 步骤 9 中的图像 1,2 Ceiva LF2003 Main Circuit Board Replacement: 步骤 9 中的图像 2,2
    • Lift up the display from the left edge and flip display over.
    • Do not lift the display too quickly, as the display is still connected to the main circuit board on the right.
  10. Ceiva LF2003 Main Circuit Board Replacement: 步骤 10 中的图像 1,3 Ceiva LF2003 Main Circuit Board Replacement: 步骤 10 中的图像 2,3 Ceiva LF2003 Main Circuit Board Replacement: 步骤 10 中的图像 3,3
    • Use the spudger to disconnect the ribbon cable from the display by the black pins away from the connector. There is a pin on either side of the connector.
    • Once both pins are released, the ribbon cable should slide easily out.
    • It may be easier if someone else holds the display so the cable does not get ripped out.
  11. Ceiva LF2003 Main Circuit Board Replacement: 步骤 11 中的图像 1,1
    • Remove the display assembly from the device.
  12. Ceiva LF2003 Main Circuit Board Replacement, Main Circuit Board: 步骤 12 中的图像 1,1
    • Remove the five 7mm Torx T6 screws.
  13. Ceiva LF2003 Main Circuit Board Replacement: 步骤 13 中的图像 1,1
    • Desolder the three wires attaching the board to the power supply.
    • In the pictures, the wires are not actually desoldered.
  14. Ceiva LF2003 Main Circuit Board Replacement: 步骤 14 中的图像 1,1
    • Desolder all the ribbon cable attachments from the board.
  15. Ceiva LF2003 Main Circuit Board Replacement: 步骤 15 中的图像 1,1
    • Remove the circuit board from the device.
    • The picture shows the board still attached to the wires, but after desoldering, the board will be completely free from the device.
结论
另外一个人完成了本指南。
Casey Glasgow
于01/26/14注册
510 声望
创作了5篇指南
团队
Cal Poly, Team 9-25, Maness Winter 2014 Cal Poly, Team 9-25, Maness Winter 2014 的会员
CPSU-MANESS-W14S9G25
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 91
