跳转到主内容
修复你的物品
维修的权力
配件 & 工具
简介
Use this guide to replace the main circuit board of the device. This requires detaching all other components, including those that are soldered to the board.
  1. Lay the device on its back, and rotate so the base is facing away from you.
    • Lay the device on its back, and rotate so the base is facing away from you.
  2. Grip the frame with your fingers under the edge of the frame, and thumbs pushing down on the front of the device.
    • Grip the frame with your fingers under the edge of the frame, and thumbs pushing down on the front of the device.
  3. Lift up the frame with your fingers and push down the rest of the device with your thumbs.
    • Lift up the frame with your fingers and push down the rest of the device with your thumbs.
  4. Remove the frame and matte from the device.
    • Remove the frame and matte from the device.
  5. Remove the four 7mm Torx T6 screws.
    • Remove the four 7mm Torx T6 screws.
  6. 任天堂 Switch 套装
    快速恢复到游戏的状态
    购买 Switch 套装
    任天堂 Switch 套装
    快速恢复到游戏的状态
    购买 Switch 套装
  7. Using the plastic opening tool or your fingers, lift up the frame from any edge. Remove the frame from the device.
    • Using the plastic opening tool or your fingers, lift up the frame from any edge.
    • Remove the frame from the device.
  8. Unplug the cable connecting the display to the power supply using the flat end of the spudger to pry the connector away from the circuit board. Alternate applying pressure to the left and right side of the connector to ensure that it does not break. Alternate applying pressure to the left and right side of the connector to ensure that it does not break.
    • Unplug the cable connecting the display to the power supply using the flat end of the spudger to pry the connector away from the circuit board.
    • Alternate applying pressure to the left and right side of the connector to ensure that it does not break.
  9. Remove the four 7mm Torx T6 screws.
  10. Lift up the display from the left edge and flip display over. Do not lift the display too quickly, as the display is still connected to the main circuit board on the right.
    • Lift up the display from the left edge and flip display over.
    • Do not lift the display too quickly, as the display is still connected to the main circuit board on the right.
  11. Use the spudger to disconnect the ribbon cable from the display by the black pins away from the connector. There is a pin on either side of the connector. Once both pins are released, the ribbon cable should slide easily out. It may be easier if someone else holds the display so the cable does not get ripped out.
    • Use the spudger to disconnect the ribbon cable from the display by the black pins away from the connector. There is a pin on either side of the connector.
    • Once both pins are released, the ribbon cable should slide easily out.
    • It may be easier if someone else holds the display so the cable does not get ripped out.
  12. Remove the display assembly from the device.
    • Remove the display assembly from the device.
  13. Remove the five 7mm Torx T6 screws.
    • Remove the five 7mm Torx T6 screws.
  14. Desolder the three wires attaching the board to the power supply.
    • Desolder the three wires attaching the board to the power supply.
    • In the pictures, the wires are not actually desoldered.
  15. Desolder all the ribbon cable attachments from the board.
    • Desolder all the ribbon cable attachments from the board.
  16. Remove the circuit board from the device.
    • Remove the circuit board from the device.
    • The picture shows the board still attached to the wires, but after desoldering, the board will be completely free from the device.
结论
另外一个人完成了本指南。
Casey Glasgow
于2014年01月26日注册
510 信誉积分
创作了5篇指南
团队
Cal Poly, Team 9-25, Maness Winter 2014 Cal Poly, Team 9-25, Maness Winter 2014 的会员
CPSU-MANESS-W14S9G25
4 名成员
创作了5篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 60
