跳转到主内容
Ceiva LF2003 Internal Plastic Screen Frame Replacement
你所需要的
  1. Ceiva LF2003 Internal Plastic Screen Frame Replacement, Exterior Frame and Matting: 步骤 1 中的图像 1,1
    • Lay the device on its back, and rotate so the base is facing away from you.
  2. Ceiva LF2003 Internal Plastic Screen Frame Replacement: 步骤 2 中的图像 1,1
    • Grip the frame with your fingers under the edge of the frame, and thumbs pushing down on the front of the device.
  3. Ceiva LF2003 Internal Plastic Screen Frame Replacement: 步骤 3 中的图像 1,1
    • Lift up the frame with your fingers and push down the rest of the device with your thumbs.
  4. Ceiva LF2003 Internal Plastic Screen Frame Replacement: 步骤 4 中的图像 1,1
    • Remove the frame and matte from the device.
  5. Ceiva LF2003 Internal Plastic Screen Frame Replacement, Internal Plastic Screen Frame: 步骤 5 中的图像 1,1
    • Remove the four 7mm Torx T6 screws.
  6. Ceiva LF2003 Internal Plastic Screen Frame Replacement: 步骤 6 中的图像 1,2 Ceiva LF2003 Internal Plastic Screen Frame Replacement: 步骤 6 中的图像 2,2
    • Using the plastic opening tool or your fingers, lift up the frame from any edge.
    • Remove the frame from the device.
结论
另外一个人完成了本指南。
Casey Glasgow
于01/26/14注册
510 声望
创作了5篇指南
团队
Cal Poly, Team 9-25, Maness Winter 2014 Cal Poly, Team 9-25, Maness Winter 2014 的会员
CPSU-MANESS-W14S9G25
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 74
