跳转到主内容
加入维修社区 - 创建账户
Ceiling Fan Light Fixture Replacement
你所需要的
  1. Ceiling Fan Light  Fixture Replacement, Light Fixture: 步骤 1 中的图像 1,3 Ceiling Fan Light  Fixture Replacement, Light Fixture: 步骤 1 中的图像 2,3 Ceiling Fan Light  Fixture Replacement, Light Fixture: 步骤 1 中的图像 3,3
    • Working with electrical wires could lead to electrocution.
    • Find your circuit breaker panel and turn off the breaker that corresponds to your ceiling lights.
    • Do this by pushing it to the right.
    • Also flip your light switch to off.
    询问修复机器人
    添加评论
  2. Ceiling Fan Light  Fixture Replacement: 步骤 2 中的图像 1,2 Ceiling Fan Light  Fixture Replacement: 步骤 2 中的图像 2,2
    • Remove the two 1.4 mm Phillips head screws that hold the fixture to the fan itself.
    • Once loose, pull down to expose the two connecting wires.
    询问修复机器人
    添加评论
  3. Ceiling Fan Light  Fixture Replacement: 步骤 3 中的图像 1,3 Ceiling Fan Light  Fixture Replacement: 步骤 3 中的图像 2,3 Ceiling Fan Light  Fixture Replacement: 步骤 3 中的图像 3,3
    • Disconnect these wires by twisting the caps in a counter-clockwise direction.
    • You only need to disconnect the wires coming from the lighting fixture.
    • Once both caps are removed, simply pull the wires apart to remove the fixture.
    询问修复机器人
    添加评论
  4. Ceiling Fan Light  Fixture Replacement: 步骤 4 中的图像 1,2 Ceiling Fan Light  Fixture Replacement: 步骤 4 中的图像 2,2
    • Loosen the nut holding the ceiling fan piece to the lighting fixture.
    • This step may require a crescent wrench if finger force is not enough.
    询问修复机器人
    添加评论
  5. Ceiling Fan Light  Fixture Replacement: 步骤 5 中的图像 1,1
    • Pull upwards to remove the fan piece that holds the light fixture.
    • Your model may require you to twist this piece in a counter-clockwise motion to remove.
    询问修复机器人
    添加评论
  6. Ceiling Fan Light  Fixture Replacement: 步骤 6 中的图像 1,1
    • Switch out the old fixture with your new fixture by doing the last two steps in reverse order.
    询问修复机器人
    添加评论
  7. Ceiling Fan Light  Fixture Replacement: 步骤 7 中的图像 1,2 Ceiling Fan Light  Fixture Replacement: 步骤 7 中的图像 2,2
    • To connect your new fixture, locate the black wire from your light and the colored wire from the fan.
    • Be sure to attached the colored wires to each other, and white wires to each other. (Positive-Positive, Negative-Negative)
    • Twist these together. Do the same with the two white wires.
    询问修复机器人
    添加评论
  8. Ceiling Fan Light  Fixture Replacement: 步骤 8 中的图像 1,2 Ceiling Fan Light  Fixture Replacement: 步骤 8 中的图像 2,2
    • Your new light fixture should come with replacement caps. Twist these in a clockwise motion over your wire ends to ensure connection.
    • The old caps work just as well for this if you were not given new ones.
    询问修复机器人
    添加评论
  9. Ceiling Fan Light  Fixture Replacement: 步骤 9 中的图像 1,1
    • Be sure to neatly tuck in all wires when re-attaching the fixture.
    • Failure to do this will result in not being able to correctly close the gap and put in the screws.
    询问修复机器人
    添加评论
  10. Ceiling Fan Light  Fixture Replacement: 步骤 10 中的图像 1,1
    • Flip your breaker back on, turn on your light switch, and enjoy your new lights!
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
12等其他人完成本指南。
团队
Cal Poly, Team 14-1, Green Fall 2015 Cal Poly, Team 14-1, Green Fall 2015 的会员
CPSU-GREEN-F15S14G1
4 名成员
创作了4篇指南
11指南评论
Amazingly instructive, informative and concise. Brilliant.
Jeanie Bolin-Moore - 回复 分享
It's awesome
Nandish Reddy - 回复 分享
Just what I needed. Thanks.
bob.mohler - 回复 分享
Does it have remote control??
ceiling fan manufacturers in india
Abhijeet Khole - 回复 分享
Could someone provide the name of the light fixture used in the demonstration?
THOMAS DUFF - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 28
过去 30 天: 168
总计 37,066
