跳转到主内容
Caterpillar B15 SIM Card Replacement
你所需要的
  1. Caterpillar B15 SIM Card Replacement, SIM Card: 步骤 1 中的图像 1,1
    • Place the phone screen-side down and place thumb on the yellow and black switch. Slide the switch to the right to unlock the back covering for removal.
  2. Caterpillar B15 SIM Card Replacement: 步骤 2 中的图像 1,2 Caterpillar B15 SIM Card Replacement: 步骤 2 中的图像 2,2
    • Remove the back covering by gently lifting upwards from the bottom of the back covering. The back will snap off and the battery is exposed.
  3. Caterpillar B15 SIM Card Replacement: 步骤 3 中的图像 1,2 Caterpillar B15 SIM Card Replacement: 步骤 3 中的图像 2,2
    • Place index finger at the top edge of the battery and gently lift upwards. The battery will slide cleanly out of the phone. The SIM card slot lies under the battery.
  4. Caterpillar B15 SIM Card Replacement: 步骤 4 中的图像 1,1
    • The old SIM card is removed and replaced with the new one. The phone can be reassembled by following these steps in reverse order.
结论
2等其他人完成本指南。
Geoffrey Mosdell
于10/06/14注册
1,119 声望
创作了5篇指南
团队
USF Tampa, Team 4-7, Brown Fall 2014 USF Tampa, Team 4-7, Brown Fall 2014 的会员
USFT-BROWN-F14S4G7
4 名成员
创作了10篇指南
一条评论
Mi celular dice SIM no detectada que puedo hacer
Jerson Vargas - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 53
总计 15,060
