跳转到主内容
Cassida Counterfeit Detector Wire on Motor Replacement
你所需要的
  1. 注意:步骤 1-6 源自标记为进行中的 指南
    Cassida Counterfeit Detector Wire on Motor Replacement, Cassida Counterfeit Detector Disassembly: 步骤 1 中的图像 1,1
    • Remove the rubber legs.
  2. Cassida Counterfeit Detector Wire on Motor Replacement: 步骤 2 中的图像 1,1
    • Using a Phillips #1 bit, remove the circled screws.
  3. Cassida Counterfeit Detector Wire on Motor Replacement: 步骤 3 中的图像 1,1
    • Pry the top cover off, starting from the side with the switch, with a metal spudger.
  4. Cassida Counterfeit Detector Wire on Motor Replacement: 步骤 4 中的图像 1,1
    • Pop the 4 tabs on the top of the machine up with a metal spudger and then remove the 2 side panels.
  5. Cassida Counterfeit Detector Wire on Motor Replacement: 步骤 5 中的图像 1,1
    • Disconnect the wires circled and then remove the top section from the bottom section just by pulling the top section straight up and holding onto the bottom.
  6. Cassida Counterfeit Detector Wire on Motor Replacement: 步骤 6 中的图像 1,1
    • All the parts disassembled.
  7. Cassida Counterfeit Detector Wire on Motor Replacement, Wire on Motor: 步骤 7 中的图像 1,1
    • Get your solder iron and set it to 660 deg Fahrenheit.
    • We recommend using 60/40 solder.
    • Solid core wire is easier to use than standard.
  8. Cassida Counterfeit Detector Wire on Motor Replacement: 步骤 8 中的图像 1,1
    • Desolder the contact point for the wire by pressing the hot iron to the contact point until the solder flows and the cable can be pulled from the board.
    • Be careful not to make skin contact with the iron.
    • For more detailed help with soldering and desoldering, check out this handy guide for tips and best practices.
  9. Cassida Counterfeit Detector Wire on Motor Replacement: 步骤 9 中的图像 1,1
    • Make sure the solder looks like so. It should look like a small mountain.
    • The motor should now be able to be removed.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 21
