跳转到主内容
Casio fx-9750GII Screen Replacement
你所需要的
  1. Casio fx-9750GII Screen Replacement, Screen: 步骤 1 中的图像 1,2 Casio fx-9750GII Screen Replacement, Screen: 步骤 1 中的图像 2,2
    • Turn off the calculator and flip it over so the backside is facing up.
    • Slide the battery door off and remove all of the batteries.
  2. Casio fx-9750GII Screen Replacement: 步骤 2 中的图像 1,1
    • Use a screwdriver to remove the screws from the back of the calculator.
  3. Casio fx-9750GII Screen Replacement: 步骤 3 中的图像 1,1
    • Carefully remove the screw from the battery slot.
  4. Casio fx-9750GII Screen Replacement: 步骤 4 中的图像 1,2 Casio fx-9750GII Screen Replacement: 步骤 4 中的图像 2,2
    • Remove the back case from the calculator.
    • Be careful of the spring that shows in the second picture. The spring is the convertor of the battery.
  5. Casio fx-9750GII Screen Replacement: 步骤 5 中的图像 1,2 Casio fx-9750GII Screen Replacement: 步骤 5 中的图像 2,2
    • Remove the screws from the motherboard.
  6. Casio fx-9750GII Screen Replacement: 步骤 6 中的图像 1,2 Casio fx-9750GII Screen Replacement: 步骤 6 中的图像 2,2
    在这个步骤中使用的工具:
    • Separate the screen cable from the motherboard using tweezers.
    • Remove the calculator screen.
    • Replace the screen.
  7. Casio fx-9750GII Screen Replacement: 步骤 7 中的图像 1,2 Casio fx-9750GII Screen Replacement: 步骤 7 中的图像 2,2
    • Replace the board and back cover of the calculator, then install the batteries to test if the new screen works well.
结论
YORK-CHEN-F21SEG[2]
于09/19/21注册
145 声望
撰写一个指南
团队
York University, Team E-2, Melo-Thaiss Fall 2021 York University, Team E-2, Melo-Thaiss Fall 2021 的会员
YORK-MELO-THAISS-F21SEG2
1 名成员
创作了3篇指南
2指南评论
thanks for the short description and pics. my screen cable appears to be soldered directly. I would help if you said more than "separate the screen cable from the motherboard" Perhaps add another pic or two of just that description? Are you breaking the wires? are you soldering on the new replacement board? are you taking off just the screen from that main 'calculator' electronics board?
Happy Zahn - 回复
Where to get the new replacement screen?
Ahmed Farhat - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 32
过去 30 天: 122
总计 4,044
