跳转到主内容
Casio MH-10M Battery Replacement
你所需要的
  1. Casio MH-10M Battery Replacement, BATTERY: 步骤 1 中的图像 1,1
    • This is the calculator in question.
    • Features a black and white dot matrix screen.
  2. Casio MH-10M Battery Replacement: 步骤 2 中的图像 1,2 Casio MH-10M Battery Replacement: 步骤 2 中的图像 2,2
    • Turn the calculator over.
    • Locate the six screws on the rear of the device.
    • These are Philips #00 screws.
    • Keep the screws you remove in a safe place so they don't get lost.
  3. Casio MH-10M Battery Replacement: 步骤 3 中的图像 1,2 Casio MH-10M Battery Replacement: 步骤 3 中的图像 2,2
    • Once the screws are removed, carefully lift the back panel off, lifting the top end first.
    • Place the panel to one side.
    • You can now see the battery.
  4. Casio MH-10M Battery Replacement: 步骤 4 中的图像 1,1
    • Remove the battery
    • Lift it up from the right hand side to avoid damaging the spring.
    • You may find this easier to do by prying it out with the screwdriver.
  5. Casio MH-10M Battery Replacement: 步骤 5 中的图像 1,2 Casio MH-10M Battery Replacement: 步骤 5 中的图像 2,2
    • Now you can insert the new battery
    • Ensure you place it in spring-first.
    • Congratulations! You have replaced the battery.
    • When reassembling, take care not to trap the red or black wires in the screws as this would sever them, making the calculator unusable.
    • Once reassembled, the calculator will be turned on. Turn it off to save battery by pressing Shift --> AC.
结论
To reassemble your device, follow these instructions in reverse order, noting the two reassembly instructions in the last step.
26等其他人完成本指南。
Sam
于09/23/12注册
959 声望
撰写一个指南
3条评论
For some reason the two top screws made the calculator unstable, but removing them made it stable. Only occurred after removing the battery
Mida Galbraith - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 15
总计 49,206
