跳转到主内容
  1. This is the calculator in question.
    • This is the calculator in question.
    • Features a black and white dot matrix screen.
  2. Turn the calculator over. Locate the six screws on the rear of the device.
    • Turn the calculator over.
    • Locate the six screws on the rear of the device.
    • These are Philips #00 screws.
    • Keep the screws you remove in a safe place so they don't get lost.
  3. Macbook 电池维修套装
    起价 $69.99
    Buy Now
    Macbook 电池维修套装
    起价 $69.99
    Buy Now
  4. Once the screws are removed, carefully lift the back panel off, lifting the top end first. Place the panel to one side.
    • Once the screws are removed, carefully lift the back panel off, lifting the top end first.
    • Place the panel to one side.
    • You can now see the battery.
  5. Remove the battery
    • Remove the battery
    • Lift it up from the right hand side to avoid damaging the spring.
    • You may find this easier to do by prying it out with the screwdriver.
  6. Now you can insert the new battery Ensure you place it in spring-first.
    • Now you can insert the new battery
    • Ensure you place it in spring-first.
    • Congratulations! You have replaced the battery.
    • When reassembling, take care not to trap the red or black wires in the screws as this would sever them, making the calculator unusable.
    • Once reassembled, the calculator will be turned on. Turn it off to save battery by pressing Shift --> AC.
结论
To reassemble your device, follow these instructions in reverse order, noting the two reassembly instructions in the last step.
23等其他人完成本指南。
Sam
于2012年09月23日注册
869 信誉积分
撰写一个指南
For some reason the two top screws made the calculator unstable, but removing them made it stable. Only occurred after removing the battery
Mida Galbraith - 回复
what battery size is it? R03?
Humerdom - 回复
添加评论
浏览统计数据:
过去的24小时: 9
过去的7天: 72
过去的30天: 341
总计 36,472
