跳转到主内容
Casio fx-580VNX Battery Replacement
你所需要的
  1. Casio fx-580VNX  Battery Replacement, Operate Shift+OFF key: 步骤 1 中的图像 1,1
    • The safest way to replace battery. Turn off is simple.
    • Do not replace the battery when it is on. If you do it, it maybe have a battery risk.
  2. Casio fx-580VNX  Battery Replacement, Remove 6 Philips Screw: 步骤 2 中的图像 1,1
    • Remove 6 Philips screw to take the cover off.
  3. Casio fx-580VNX  Battery Replacement, Open the case: 步骤 3 中的图像 1,1
    • Carefully remove the case or the cover. Don't remove too much power.
  4. Casio fx-580VNX  Battery Replacement, Remove a Old Battery: 步骤 4 中的图像 1,1
    • Removing the battery is the way to replace a new battery. You can remove our old battery to new battery.
  5. Casio fx-580VNX  Battery Replacement, Battery removed: 步骤 5 中的图像 1,1
    • The old battery have removed. You can replace with the new battery.
结论
Before you use the calculator after replacing, operate the key: Shift+9(Reset), press 3 then press =.
Nazomi Inc
于05/26/20注册
1,156 声望
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 13
过去 30 天: 38
总计 939
