跳转到主内容
Casio fx-300ES Plus 2nd Edition Battery Replacement
你所需要的
  1. Casio fx-300ES Plus 2nd Edition Battery Replacement, Battery Replacement: 步骤 1 中的图像 1,1
    • Press (Shift + AC) to turn off the calculator.
  2. Casio fx-300ES Plus 2nd Edition Battery Replacement: 步骤 2 中的图像 1,3 Casio fx-300ES Plus 2nd Edition Battery Replacement: 步骤 2 中的图像 2,3 Casio fx-300ES Plus 2nd Edition Battery Replacement: 步骤 2 中的图像 3,3
    • Use a Phillips #00 screwdriver to remove the six 7.5 mm screws from the back panel.
    • Insert an opening pick in the seam between the top and bottom casing.
    • Slide it around the perimeter of the calculator to release the clips that connect the front and back panels.
    • Carefully separate the front and back halves of the calculator casing.
  3. Casio fx-300ES Plus 2nd Edition Battery Replacement: 步骤 3 中的图像 1,3 Casio fx-300ES Plus 2nd Edition Battery Replacement: 步骤 3 中的图像 2,3 Casio fx-300ES Plus 2nd Edition Battery Replacement: 步骤 3 中的图像 3,3
    • Use a plastic spudger or opening pick to remove the old battery.
  4. Casio fx-300ES Plus 2nd Edition Battery Replacement: 步骤 4 中的图像 1,1
    • Insert the new LR44 battery into the compartment with the positive (+) side facing up.
  5. Casio fx-300ES Plus 2nd Edition Battery Replacement: 步骤 5 中的图像 1,2 Casio fx-300ES Plus 2nd Edition Battery Replacement: 步骤 5 中的图像 2,2
    • Replace the panel on the back of the calculator and use a Phillips #00 screwdriver to secure the six 7.5 mm Philips #00 screws.
  6. Casio fx-300ES Plus 2nd Edition Battery Replacement: 步骤 6 中的图像 1,2 Casio fx-300ES Plus 2nd Edition Battery Replacement: 步骤 6 中的图像 2,2
    • Power on the calculator, then bring up the 'clear' menu by pressing (SHIFT + 9).
  7. Casio fx-300ES Plus 2nd Edition Battery Replacement: 步骤 7 中的图像 1,3 Casio fx-300ES Plus 2nd Edition Battery Replacement: 步骤 7 中的图像 2,3 Casio fx-300ES Plus 2nd Edition Battery Replacement: 步骤 7 中的图像 3,3
    • Perform a restoration of the calculator's default settings.
    • The order to press is (SHIFT, 9, 1, =).
结论
You've done it! ;)
另外一个人完成了本指南。
Andrei John Tabanao
于01/07/25注册
163 声望
撰写一个指南
团队
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 29
总计 274
