跳转到主内容
简介
This guide will show you how to remove, clean, and replace the black keys of the keyboard
  1. Place device face-down Remove 23 16mm screws with Phillips #2 screwdriver
    • Place device face-down
    • Remove 23 16mm screws with Phillips #2 screwdriver
  2. Pry up long back panels with plastic opening tool Remove panels
    • Pry up long back panels with plastic opening tool
    • Remove panels
  3. Turn device around so keys are face-up
    • Turn device around so keys are face-up
  4. Pull back panel away from keyboard and out of the way Pull back panel away from keyboard and out of the way
    • Pull back panel away from keyboard and out of the way
  5. Remove speaker(s) if necessary to access desired key section(s) Use Phillips #2 screwdriver to remove two 16 mm screws (circled in red) Pop wires out of plastic holders so speaker can be moved out of the way
    • Remove speaker(s) if necessary to access desired key section(s)
    • Use Phillips #2 screwdriver to remove two 16 mm screws (circled in red)
    • Pop wires out of plastic holders so speaker can be moved out of the way
    • Move speaker out of the way
    • See speaker replacement guide for more detail on these steps
  6. Remove 4 18 mm screws (circled in red) from desired key section using Philips #1 screwdriver Gently push white keys away from screws and pull up to remove from keyboard. Repeat this with the black keys Reassemble with new/cleaned keys
    • Remove 4 18 mm screws (circled in red) from desired key section using Philips #1 screwdriver
    • Gently push white keys away from screws and pull up to remove from keyboard. Repeat this with the black keys
    • Reassemble with new/cleaned keys
结论
Alexa
于2017年01月24日注册
651 信誉积分
创作了6篇指南
团队
Cal Poly, Team 10-2, Banghart Winter 2017 Cal Poly, Team 10-2, Banghart Winter 2017 的会员
CPSU-BANGHART-W17S10G2
4 名成员
创作了6篇指南
一条评论
Hi. Will this work for broken keys please?
Deborah - EDEN Henderson - 回复
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 3
过去的30天: 7
总计 1,062
