跳转到主内容
Casio WK-220 Black Keys Replacement
你所需要的
  1. Casio WK-220 Black Keys Replacement, White Keys: 步骤 1 中的图像 1,2 Casio WK-220 Black Keys Replacement, White Keys: 步骤 1 中的图像 2,2
    • Place device face-down
    • Remove 23 16mm screws with Phillips #2 screwdriver
  2. Casio WK-220 Black Keys Replacement: 步骤 2 中的图像 1,2 Casio WK-220 Black Keys Replacement: 步骤 2 中的图像 2,2
    • Pry up long back panels with plastic opening tool
    • Remove panels
  3. Casio WK-220 Black Keys Replacement: 步骤 3 中的图像 1,1
    • Turn device around so keys are face-up
  4. Casio WK-220 Black Keys Replacement: 步骤 4 中的图像 1,2 Casio WK-220 Black Keys Replacement: 步骤 4 中的图像 2,2
    • Pull back panel away from keyboard and out of the way
  5. Casio WK-220 Black Keys Replacement: 步骤 5 中的图像 1,3 Casio WK-220 Black Keys Replacement: 步骤 5 中的图像 2,3 Casio WK-220 Black Keys Replacement: 步骤 5 中的图像 3,3
    • Remove speaker(s) if necessary to access desired key section(s)
    • Use Phillips #2 screwdriver to remove two 16 mm screws (circled in red)
    • Pop wires out of plastic holders so speaker can be moved out of the way
    • Move speaker out of the way
    • See speaker replacement guide for more detail on these steps
  6. Casio WK-220 Black Keys Replacement: 步骤 6 中的图像 1,3 Casio WK-220 Black Keys Replacement: 步骤 6 中的图像 2,3 Casio WK-220 Black Keys Replacement: 步骤 6 中的图像 3,3
    • Remove 4 18 mm screws (circled in red) from desired key section using Philips #1 screwdriver
    • Gently push white keys away from screws and pull up to remove from keyboard. Repeat this with the black keys
    • Reassemble with new/cleaned keys
  7. Casio WK-220 Black Keys Replacement, Black Keys: 步骤 7 中的图像 1,2 Casio WK-220 Black Keys Replacement, Black Keys: 步骤 7 中的图像 2,2
    • Remove second white section covering desired black section
    • Remove screws using Phillips #1 screwdriver
    • Push keys away from screws and pull up
  8. Casio WK-220 Black Keys Replacement: 步骤 8 中的图像 1,3 Casio WK-220 Black Keys Replacement: 步骤 8 中的图像 2,3 Casio WK-220 Black Keys Replacement: 步骤 8 中的图像 3,3
    • Use plastic opening tool to pry up black key section
    • Remove black key section
    • Reassemble with new/clean black key section
结论
Alexa
于01/24/17注册
687 声望
创作了6篇指南
团队
Cal Poly, Team 10-2, Banghart Winter 2017 Cal Poly, Team 10-2, Banghart Winter 2017 的会员
CPSU-BANGHART-W17S10G2
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 16
总计 789
