跳转到主内容
Casio SPF-40 2273 Battery Replacement
你所需要的
  1. Casio SPF-40 2273 Battery Replacement, Battery: 步骤 1 中的图像 1,3 Casio SPF-40 2273 Battery Replacement, Battery: 步骤 1 中的图像 2,3 Casio SPF-40 2273 Battery Replacement, Battery: 步骤 1 中的图像 3,3
    • This super strong Casio watch is more docile than waht you might think.
    • We don't need to twist off the front's screws.
    • It doesn't bite, so let's turn it around
  2. Casio SPF-40 2273 Battery Replacement: 步骤 2 中的图像 1,3 Casio SPF-40 2273 Battery Replacement: 步骤 2 中的图像 2,3 Casio SPF-40 2273 Battery Replacement: 步骤 2 中的图像 3,3
    在这个步骤中使用的工具:
    • With the phillips screwdriver take off these four screws
    • Lift up an extremity of the watchstrap and remove the base.
    • You can use a flat screwdriver to help you
    • With the tweezers lift the white plastic cover
    • Be careful to not damage the golden springs!! So take your time
  3. Casio SPF-40 2273 Battery Replacement: 步骤 3 中的图像 1,3 Casio SPF-40 2273 Battery Replacement: 步骤 3 中的图像 2,3 Casio SPF-40 2273 Battery Replacement: 步骤 3 中的图像 3,3
    • With the tip of the tweezers you have to unclip the clips into the red rectangles.
    • Just insert the tweezer's tip in the center of the bracket and pull toward the center of the watch
  4. Casio SPF-40 2273 Battery Replacement: 步骤 4 中的图像 1,3 Casio SPF-40 2273 Battery Replacement: 步骤 4 中的图像 2,3 Casio SPF-40 2273 Battery Replacement: 步骤 4 中的图像 3,3
    • Extract the battery leveraging with the tweezers.
    • Keep attention to the golden springs again!
    • The clip, holding down the central batteries, completely removes
结论
5等其他人完成本指南。
Acn0w
于09/20/18注册
15,579 声望
撰写一个指南
5指南评论
cannot see the “Golden Springs”. Where are they? Thank you
mike.malapascua - 回复
would be nice to have a description if the battery type, to buy before disassembling.. Thank you
mike
Sorry if I wasn’t imprecise, the “Golden Springs” is located above the first battery on the left. More precisely in second step of the guide I marked it.
Coin shaped Batteries are Sony SR927W:
* 1.55 Volt
* 60 mAh
Acn0w -
What about the sticker „After battery replacment, contact AC with battery(+) using tweezers“ ?
ameyer - 回复
Come devo riavviare? Non si accende grazie
stefano chirio - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 32
过去 30 天: 155
总计 12,202
