跳转到主内容
Casio MTD-120 Battery Replacement
你所需要的
  1. Casio MTD-120 Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Place the watch upside down.
  2. Casio MTD-120 Battery Replacement: 步骤 2 中的图像 1,2 Casio MTD-120 Battery Replacement: 步骤 2 中的图像 2,2
    在这个步骤中使用的工具:
    • Remove the back cover of the watch with tweezers.
    • This should reveal a plastic cover once the back is removed.
  3. Casio MTD-120 Battery Replacement: 步骤 3 中的图像 1,2 Casio MTD-120 Battery Replacement: 步骤 3 中的图像 2,2
    • Remove the plastic cover with the tweezers.
    • You should now see the battery compartment.
  4. Casio MTD-120 Battery Replacement: 步骤 4 中的图像 1,1
    • Remove the battery with the tweezers.
    • Use your fingers to remove the battery if you find it difficult using the tweezers.
  5. Casio MTD-120 Battery Replacement: 步骤 5 中的图像 1,1
    • Insert the new battery by pushing down gently.
    • The battery needed for this watch is an SR920SW.
    • Recycle the old battery.
    • Where To Recycle Batteries
  6. Casio MTD-120 Battery Replacement: 步骤 6 中的图像 1,2 Casio MTD-120 Battery Replacement: 步骤 6 中的图像 2,2
    • Place the plastic cover back over battery compartment.
    • Align the marked area of the plastic cover with the crown of the watch.
    • The crown is the knob that is used to set the watch.
  7. Casio MTD-120 Battery Replacement: 步骤 7 中的图像 1,1
    • Put the cover back and tighten it shut by pressing on it.
结论
Follow the link provided in step 5 to find more information on recycling your old batteries.
2等其他人完成本指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 31
总计 5,132
