跳转到主内容
Casio G'zOne Commando Verizon MIL-SPEC Sim Card Replacement
你所需要的
  1. Casio G'zOne Commando Verizon MIL-SPEC Sim Card Replacement, Battery: 步骤 1 中的图像 1,1
    • Slide the slider on the back of the phone to the free position.
  2. Casio G'zOne Commando Verizon MIL-SPEC Sim Card Replacement: 步骤 2 中的图像 1,1
    • Using a plastic opening tool, gently lift open the back panel from bottom of the panel.
  3. Casio G'zOne Commando Verizon MIL-SPEC Sim Card Replacement: 步骤 3 中的图像 1,2 Casio G'zOne Commando Verizon MIL-SPEC Sim Card Replacement: 步骤 3 中的图像 2,2
    • Pull the white battery tab upwards and remove the battery.
  4. Casio G'zOne Commando Verizon MIL-SPEC Sim Card Replacement, Sim Card: 步骤 4 中的图像 1,1
    • Using a spudger, gently open the metal tab up. Now, it is ready for you to insert the new SIM card.
结论
Zack Almeida
于10/24/18注册
392 声望
创作了4篇指南
团队
UMass Dartmouth, Team S3-G7, Peak Fall 2018 UMass Dartmouth, Team S3-G7, Peak Fall 2018 的会员
UMASSD-PEAK-F18S3G7
3 名成员
创作了8篇指南
一条评论
i believe that is the memory card, not the sim card!
Joshua Vaillancourt - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 34
总计 2,355
