跳转到主内容
Casio G'zOne Commando Verizon MIL-SPEC Camera Replacement
你所需要的
  1. Casio G'zOne Commando Verizon MIL-SPEC Camera Replacement, Battery: 步骤 1 中的图像 1,1
    • Slide the slider on the back of the phone to the free position.
  2. Casio G'zOne Commando Verizon MIL-SPEC Camera Replacement: 步骤 2 中的图像 1,1
    • Using a plastic opening tool, gently lift open the back panel from bottom of the panel.
  3. Casio G'zOne Commando Verizon MIL-SPEC Camera Replacement: 步骤 3 中的图像 1,2 Casio G'zOne Commando Verizon MIL-SPEC Camera Replacement: 步骤 3 中的图像 2,2
    • Pull the white battery tab upwards and remove the battery.
  4. Casio G'zOne Commando Verizon MIL-SPEC Camera Replacement, Motherboard: 步骤 4 中的图像 1,1
    • Remove the four 6mm Y0 screws from the corners of the device.
  5. Casio G'zOne Commando Verizon MIL-SPEC Camera Replacement: 步骤 5 中的图像 1,1
    • Remove the four 5mm Y0 screws from the back of the device.
  6. Casio G'zOne Commando Verizon MIL-SPEC Camera Replacement: 步骤 6 中的图像 1,1
    • Using a spudger, pry away the motherboard from its compartment, by inserting the spudger in the compartment and lifting upwards until fully out.
  7. Casio G'zOne Commando Verizon MIL-SPEC Camera Replacement: 步骤 7 中的图像 1,1
    • Lastly, using your hands, separate the motherboard from its compartment.
  8. Casio G'zOne Commando Verizon MIL-SPEC Camera Replacement, Camera: 步骤 8 中的图像 1,3 Casio G'zOne Commando Verizon MIL-SPEC Camera Replacement, Camera: 步骤 8 中的图像 2,3 Casio G'zOne Commando Verizon MIL-SPEC Camera Replacement, Camera: 步骤 8 中的图像 3,3
    • Using a spudger, gently lift up the orange connector.
  9. Casio G'zOne Commando Verizon MIL-SPEC Camera Replacement: 步骤 9 中的图像 1,2 Casio G'zOne Commando Verizon MIL-SPEC Camera Replacement: 步骤 9 中的图像 2,2
    • Flip over the motherboard
    • Using a spudger, lift up the small black connector and remove the camera.
结论
Zack Almeida
于10/24/18注册
392 声望
创作了4篇指南
团队
UMass Dartmouth, Team S3-G7, Peak Fall 2018 UMass Dartmouth, Team S3-G7, Peak Fall 2018 的会员
UMASSD-PEAK-F18S3G7
3 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 11
总计 173
