跳转到主内容
Casio G’zOne Commando 4G LTE Sim Card Replacement
你所需要的
  1. Casio G’zOne Commando 4G LTE Sim Card Replacement, Battery: 步骤 1 中的图像 1,1
    • In order to get at the battery, you will have to pull the locking tab to the “Free” position. Once you do that you will have to pry the battery cover off (using a plastic opening tool or similar prying tool). Because the phone is designed to be waterproof, it is advised that you do NOT use your fingernails.
  2. Casio G’zOne Commando 4G LTE Sim Card Replacement: 步骤 2 中的图像 1,2 Casio G’zOne Commando 4G LTE Sim Card Replacement: 步骤 2 中的图像 2,2
    • Once the battery cover is off, there is another lock holding the battery in place. However, with this lock all you have to do is slide the lock to “Free”, and pull the battery out by lifting it from the bottom side (the side with the orange lock).
  3. Casio G’zOne Commando 4G LTE Sim Card Replacement, Sim Card: 步骤 3 中的图像 1,1
    • After removing the battery you will find a port that is labeled SIM directly beneath where the battery was sitting.
  4. Casio G’zOne Commando 4G LTE Sim Card Replacement: 步骤 4 中的图像 1,1
    • In order to remove the SD card lift the tab that is located directly to the left of the card. Then slide the SD card out of its port and remove it from the cell phone.
结论
3等其他人完成本指南。
Keith Hickey
于10/29/15注册
428 声望
创作了3篇指南
团队
UMass Dartmouth, Team 1-9, Miles Fall 2015 UMass Dartmouth, Team 1-9, Miles Fall 2015 的会员
UMASSD-MILES-F15S1G9
3 名成员
创作了10篇指南
2条评论
My Casio C811 will not go to a browser, keeps saying no network connection. I am in an area that I have had connection with no problems before. The phone did some sort of reset on it own and now wont access any browser, google, Facebook ect. I have check the network setting and they appear OK. Any suggestions
bernmntsa - 回复
How do I unlock my Casio Commando C811 to use with non-verizon SIM…!?
Alrn Arun - 回复
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 6
过去 30 天: 30
总计 4,562
