跳转到主内容
Casio G’zOne Commando 4G LTE Motherboard Replacement
已存档的指南
本指南只作为历史记录保留。请使用指南的最新版本来进行维修。
你所需要的
  1. Casio G’zOne Commando 4G LTE Motherboard Replacement, Open back cover.: 步骤 1 中的图像 1,1
    • This device is waterproof and well sealed, so it is difficult to open this handset.
    • Start by opening the cover of the handset.
    • Do not use your nails to open the cover. Use the iFixit Opening Tool (refer to the image).
  2. Casio G’zOne Commando 4G LTE Motherboard Replacement, Free and remove the battery: 步骤 2 中的图像 1,2 Casio G’zOne Commando 4G LTE Motherboard Replacement, Free and remove the battery: 步骤 2 中的图像 2,2
    • Move the orange tab to the right side to take out the battery.
    • Remove the battery.
  3. Casio G’zOne Commando 4G LTE Motherboard Replacement, Remove front and back screws: 步骤 3 中的图像 1,2 Casio G’zOne Commando 4G LTE Motherboard Replacement, Remove front and back screws: 步骤 3 中的图像 2,2
    • Using the Phillips #00 screwdriver remove the front and back 5.0 mm screws as shown in the picture.
    • There are four screws in the back and two screws in the front.
  4. Casio G’zOne Commando 4G LTE Motherboard Replacement, Remove side-Back cover: 步骤 4 中的图像 1,3 Casio G’zOne Commando 4G LTE Motherboard Replacement, Remove side-Back cover: 步骤 4 中的图像 2,3 Casio G’zOne Commando 4G LTE Motherboard Replacement, Remove side-Back cover: 步骤 4 中的图像 3,3
    • Gently remove the side cover from the phone by lifting up on the corners as shown in the picture.
    • Press down on the screen to help remove the plastic side cover from the phone.
    • Make sure to push gently because the frame is fragile.
  5. Casio G’zOne Commando 4G LTE Motherboard Replacement, Remove Side-Front cover: 步骤 5 中的图像 1,1
    • Pull the side front cover off the face of the phone.
  6. Casio G’zOne Commando 4G LTE Motherboard Replacement: 步骤 6 中的图像 1,3 Casio G’zOne Commando 4G LTE Motherboard Replacement: 步骤 6 中的图像 2,3 Casio G’zOne Commando 4G LTE Motherboard Replacement: 步骤 6 中的图像 3,3
    • Remove the eight 2.5mm Phillips #00 screws in the holes of the casing.
  7. Casio G’zOne Commando 4G LTE Motherboard Replacement: 步骤 7 中的图像 1,1
    • Gently pull off the motherboard cover.
  8. Casio G’zOne Commando 4G LTE Motherboard Replacement: 步骤 8 中的图像 1,1
    • Using the Phillips #00, remove all 2.5 mm screws attached to the motherboard.
    • Do not touch the integrated circuits in the motherboard.
  9. Casio G’zOne Commando 4G LTE Motherboard Replacement, Motherboard: 步骤 9 中的图像 1,2 Casio G’zOne Commando 4G LTE Motherboard Replacement, Motherboard: 步骤 9 中的图像 2,2
    • Gently remove the motherboard with the spudger.
结论
4等其他人完成本指南。
Brett Boehm
于09/25/14注册
281 声望
创作了2篇指南
团队
USF Tampa, Team 1-5, Brown Fall 2014 USF Tampa, Team 1-5, Brown Fall 2014 的会员
USFT-BROWN-F14S1G5
3 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 14
总计 835
