跳转到主内容
Casio G’zOne Commando 4G LTE Camera Replacement
你所需要的
  1. Casio G’zOne Commando 4G LTE Camera Replacement, Motherboard: 步骤 1 中的图像 1,1
    • First, you are going to want to take out the two front screws from the device.
    • The screws are 4mm in length and require a Y0 bit to remove
  2. Casio G’zOne Commando 4G LTE Camera Replacement: 步骤 2 中的图像 1,1
    • Using the same screw head, remove the back four screws from the device.
  3. Casio G’zOne Commando 4G LTE Camera Replacement: 步骤 3 中的图像 1,2 Casio G’zOne Commando 4G LTE Camera Replacement: 步骤 3 中的图像 2,2
    • You should have taken out six screws (two from the front, four from the back). Once you do this, you will have to separate the front and back casing of the phone using a spudger or pry tool.
  4. Casio G’zOne Commando 4G LTE Camera Replacement: 步骤 4 中的图像 1,1
    • Now, you have six more screws to unscrew (three on each side). They are all the same size but smaller than the first six we took off.
    • These screws are 4mm in length and require a PH00 tip to remove.
  5. Casio G’zOne Commando 4G LTE Camera Replacement: 步骤 5 中的图像 1,1
    • Once you unscrew all six screws, you can easily separate the plastic shell with your hands.
  6. Casio G’zOne Commando 4G LTE Camera Replacement: 步骤 6 中的图像 1,2 Casio G’zOne Commando 4G LTE Camera Replacement: 步骤 6 中的图像 2,2
    • Again, there are six more (and even smaller) screws to take out. Additionally, you have to disconnect a small wire plugged into the motherboard.
    • These screws are 2mm in length and require a PH000 tip to remove.
  7. Casio G’zOne Commando 4G LTE Camera Replacement: 步骤 7 中的图像 1,2 Casio G’zOne Commando 4G LTE Camera Replacement: 步骤 7 中的图像 2,2
    • After removing the screws carefully separate the motherboard from the shell with the spudger.
  8. Casio G’zOne Commando 4G LTE Camera Replacement, Camera: 步骤 8 中的图像 1,1
    • In order to remove the camera, carefully disconnect the wires with the metal spudger.
  9. Casio G’zOne Commando 4G LTE Camera Replacement: 步骤 9 中的图像 1,3 Casio G’zOne Commando 4G LTE Camera Replacement: 步骤 9 中的图像 2,3 Casio G’zOne Commando 4G LTE Camera Replacement: 步骤 9 中的图像 3,3
    • After disconnecting the wires, remove the camera by putting slight pressure of the optical camera lens. The camera the will pop out of the motherboard.
结论
另外一个人完成了本指南。
Keith Hickey
于10/29/15注册
428 声望
创作了3篇指南
团队
UMass Dartmouth, Team 1-9, Miles Fall 2015 UMass Dartmouth, Team 1-9, Miles Fall 2015 的会员
UMASSD-MILES-F15S1G9
3 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 4
过去 30 天: 13
总计 420
