跳转到主内容
Casio G’zOne Commando 4G LTE Battery Replacement
你所需要的
  1. Casio G’zOne Commando 4G LTE Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • In order to get at the battery, you will have to pull the locking tab to the “Free” position. Once you do that you will have to pry the battery cover off (using a plastic opening tool or similar prying tool). Because the phone is designed to be waterproof, it is advised that you do NOT use your fingernails.
  2. Casio G’zOne Commando 4G LTE Battery Replacement: 步骤 2 中的图像 1,2 Casio G’zOne Commando 4G LTE Battery Replacement: 步骤 2 中的图像 2,2
    • Once the battery cover is off, there is another lock holding the battery in place. However, with this lock all you have to do is slide the lock to “Free”, and pull the battery out by lifting it from the bottom side (the side with the orange lock).
结论
To install a new battery in your device, follow these instructions in reverse order.
另外一个人完成了本指南。
Daniel Keenan
于10/28/15注册
374 声望
创作了2篇指南
团队
UMass Dartmouth, Team 1-9, Miles Fall 2015 UMass Dartmouth, Team 1-9, Miles Fall 2015 的会员
UMASSD-MILES-F15S1G9
3 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 6
过去 30 天: 15
总计 748
