跳转到主内容
Casio Exilim EX-Z850 lens assembly replacement
你所需要的
  1. Casio Exilim EX-Z850 lens assembly replacement, Zoom Lens: 步骤 1 中的图像 1,1
    • Remove the four screws on the side with the screwdriver.
  2. Casio Exilim EX-Z850 lens assembly replacement: 步骤 2 中的图像 1,1
    • Remove the four screws from the bottom of the camera.
    • Bottom screws are longer than the top ones, so keep that in mind for easy reassembly
  3. Casio Exilim EX-Z850 lens assembly replacement: 步骤 3 中的图像 1,1
    • With the screwdriver, remove the four screws on the side of the speaker.
  4. Casio Exilim EX-Z850 lens assembly replacement: 步骤 4 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Once all screws have been removed, gently pry open the bottom casing.
    • With tweezers, carefully remove ribbon from LCD screen.
    • Set the bottom casing aside.
  5. Casio Exilim EX-Z850 lens assembly replacement: 步骤 5 中的图像 1,2 Casio Exilim EX-Z850 lens assembly replacement: 步骤 5 中的图像 2,2
    • Remove ribbon from the rear casing.
    • Set aside the rear casing.
  6. Casio Exilim EX-Z850 lens assembly replacement: 步骤 6 中的图像 1,2 Casio Exilim EX-Z850 lens assembly replacement: 步骤 6 中的图像 2,2
    • Use tweezers or prongs to pry the LCD screen off from the opening.
    • Note: the bottom of the LCD screen is attached to the frame by a few pieces of black tape.
  7. Casio Exilim EX-Z850 lens assembly replacement: 步骤 7 中的图像 1,2 Casio Exilim EX-Z850 lens assembly replacement: 步骤 7 中的图像 2,2
    • Lift up the LCD screen, and slowly move it to the other side.
  8. Casio Exilim EX-Z850 lens assembly replacement: 步骤 8 中的图像 1,2 Casio Exilim EX-Z850 lens assembly replacement: 步骤 8 中的图像 2,2
    • With tweezers, pry off the LCD casing which is taped on to the frame.
  9. Casio Exilim EX-Z850 lens assembly replacement: 步骤 9 中的图像 1,3 Casio Exilim EX-Z850 lens assembly replacement: 步骤 9 中的图像 2,3 Casio Exilim EX-Z850 lens assembly replacement: 步骤 9 中的图像 3,3
    • With tweezers, flip open the connector holding the ribbon.
    • Pull out the LCD screen with the ribbon from the camera.
  10. Casio Exilim EX-Z850 lens assembly replacement: 步骤 10 中的图像 1,2 Casio Exilim EX-Z850 lens assembly replacement: 步骤 10 中的图像 2,2
    • Pull apart the front casing, and set it to the side.
  11. Casio Exilim EX-Z850 lens assembly replacement: 步骤 11 中的图像 1,2 Casio Exilim EX-Z850 lens assembly replacement: 步骤 11 中的图像 2,2
    • Remove two screws on the side where the battery is located.
    • Remove the lanyard loop after the screws come off.
    • Slowly pull the side casing so it becomes dislocated from the top of the camera frame.
  12. Casio Exilim EX-Z850 lens assembly replacement: 步骤 12 中的图像 1,2 Casio Exilim EX-Z850 lens assembly replacement: 步骤 12 中的图像 2,2
    • On the front of the camera near the flash flip the connector holding the ribbon.
    • Carefully remove the ribbon from the connector.
  13. Casio Exilim EX-Z850 lens assembly replacement: 步骤 13 中的图像 1,3 Casio Exilim EX-Z850 lens assembly replacement: 步骤 13 中的图像 2,3 Casio Exilim EX-Z850 lens assembly replacement: 步骤 13 中的图像 3,3
    • Carefully remove the L shaped frame from the camera.
    • At the bottom of the camera the L shaped frame is being held in by two plastic bumps and a metal tab. Pop the frame off the bumps and tabs.
    • There is a yellow and orange wire soldered onto the camera. Be careful not to pull them off.
  14. Casio Exilim EX-Z850 lens assembly replacement: 步骤 14 中的图像 1,2 Casio Exilim EX-Z850 lens assembly replacement: 步骤 14 中的图像 2,2
    • On the logic board next to the lens is a connector with a ribbon.
    • Flip the connector and remove the ribbon with the tweezers.
  15. Casio Exilim EX-Z850 lens assembly replacement: 步骤 15 中的图像 1,2 Casio Exilim EX-Z850 lens assembly replacement: 步骤 15 中的图像 2,2
    • Remove the frame on the back side of the camera where the LCD screen was.
    • With the screwdriver, remove the two screws connecting the frame with the camera
    • Slowly pry off the frame from the camera
    • After removing the frame a plastic piece with two yellow button connections should fall off.
    • Note: This plastic piece is soldered to two wires a yellow and orange one.
  16. Casio Exilim EX-Z850 lens assembly replacement: 步骤 16 中的图像 1,1
    • On the back of the camera where the LCD screen was, remove the 3 screws located behind the lens.
  17. Casio Exilim EX-Z850 lens assembly replacement: 步骤 17 中的图像 1,1
    • Remove the large orange ribbon previously held in by screws from the camera and set it asside.
  18. Casio Exilim EX-Z850 lens assembly replacement: 步骤 18 中的图像 1,1
    • On the backside of the camera where the indicator lamp is located, remove the two screws with a screwdriver
  19. Casio Exilim EX-Z850 lens assembly replacement: 步骤 19 中的图像 1,3 Casio Exilim EX-Z850 lens assembly replacement: 步骤 19 中的图像 2,3 Casio Exilim EX-Z850 lens assembly replacement: 步骤 19 中的图像 3,3
    • On the side of the indicator lamp remove a screw.
    • On the front side of the indicator lamp remove the a screw.
    • This should remove the indicator lamp from the lens.
  20. Casio Exilim EX-Z850 lens assembly replacement: 步骤 20 中的图像 1,2 Casio Exilim EX-Z850 lens assembly replacement: 步骤 20 中的图像 2,2
    • The lens is now detached from the camera except for the ribbon soldered onto the logic board.
结论
To put the Casio Exilim EX-Z850 camera back together, reserve the instructions to follow them in a backward manner.
2等其他人完成本指南。
Ray
于01/25/11注册
219 声望
撰写一个指南
团队
Cal Poly, Team 4-38, Regan Winter 2011 Cal Poly, Team 4-38, Regan Winter 2011 的会员
CPSU-REGAN-W11S4G38
4 名成员
创作了13篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 14
总计 8,436
