当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Using the Phillips #00 screwdriver, remove the four long screws from the bottom of the camera.
When reassembling the camera, the longer screws go on the bottom of the camera.
Pry open bottom casing gently after all screws have been removed.
With tweezers, carefully remove the ribbon from the LCD screen.
Set the bottom casing aside.
Pry apart the top casing using tweezers.
Set the top casing aside.
The bottom left screw on the board is orange and the longest screw.
Using the Phillips #00 screwdriver, remove two screws on the side where the battery is located.
Remove the lanyard loop after the screws come off.
Pull the side casing so it becomes dislocated from the top of the camera frame.
On the front of the camera near the flash, flip the connector holding the ribbon.
Remove the ribbon from the connector.
Carefully remove the L-shaped frame from the camera.
The L shaped frame is being held in by two plastic bumps and a metal tab at the bottom of the camera.
Pop the frame off the bumps and tabs.
Potential for device damage: Be careful not to pull off the yellow and orange wire soldered onto the camera.
Remove the frame on the back side of the camera where the LCD screen was.
Use the Phillips #00 screwdriver to remove the two screws connecting the frame to the camera.
Slowly pry off the frame from the camera.
After removing the frame, a plastic piece with two yellow buttons should fall off.
Do not pull the plastic piece off as it is soldered to two wires: a yellow and orange one.
Desolder the lens from the motherboard.
Desolder the wire from the motherboard.
The motherboard is now detached from the rest of the camera.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
