跳转到主内容
Casio Exilim EX-Z850 Motherboard Replacement
你所需要的
  1. Casio Exilim EX-Z850 Motherboard Replacement, Motherboard: 步骤 1 中的图像 1,1
    • Using the Phillips #00 screwdriver, remove the four screws from the side of the speaker.
  2. Casio Exilim EX-Z850 Motherboard Replacement: 步骤 2 中的图像 1,1
    • Using the Phillips #00 screwdriver, remove the four long screws from the bottom of the camera.
    • When reassembling the camera, the longer screws go on the bottom of the camera.
  3. Casio Exilim EX-Z850 Motherboard Replacement: 步骤 3 中的图像 1,1
    • Using the Phillips #00 screwdriver, remove the four screws from the side opposite of the speaker.
  4. Casio Exilim EX-Z850 Motherboard Replacement: 步骤 4 中的图像 1,3 Casio Exilim EX-Z850 Motherboard Replacement: 步骤 4 中的图像 2,3 Casio Exilim EX-Z850 Motherboard Replacement: 步骤 4 中的图像 3,3
    • Pry open bottom casing gently after all screws have been removed.
    • With tweezers, carefully remove the ribbon from the LCD screen.
    • Set the bottom casing aside.
  5. Casio Exilim EX-Z850 Motherboard Replacement: 步骤 5 中的图像 1,3 Casio Exilim EX-Z850 Motherboard Replacement: 步骤 5 中的图像 2,3 Casio Exilim EX-Z850 Motherboard Replacement: 步骤 5 中的图像 3,3
    • Pry apart the top casing using tweezers.
    • Set the top casing aside.
    • The bottom left screw on the board is orange and the longest screw.
  6. Casio Exilim EX-Z850 Motherboard Replacement: 步骤 6 中的图像 1,2 Casio Exilim EX-Z850 Motherboard Replacement: 步骤 6 中的图像 2,2
    • Carefully remove the pieces of black tape on the bottom of the LCD screen that attach it to the frame.
    • Use tweezers to pry the LCD screen off from the opening.
  7. Casio Exilim EX-Z850 Motherboard Replacement: 步骤 7 中的图像 1,2 Casio Exilim EX-Z850 Motherboard Replacement: 步骤 7 中的图像 2,2
    • Lift the LCD screen and move it to the other side.
  8. Casio Exilim EX-Z850 Motherboard Replacement: 步骤 8 中的图像 1,2 Casio Exilim EX-Z850 Motherboard Replacement: 步骤 8 中的图像 2,2
    • Using a pair of tweezers, pry off the LCD casing.
  9. Casio Exilim EX-Z850 Motherboard Replacement: 步骤 9 中的图像 1,3 Casio Exilim EX-Z850 Motherboard Replacement: 步骤 9 中的图像 2,3 Casio Exilim EX-Z850 Motherboard Replacement: 步骤 9 中的图像 3,3
    • Flip open the connector holding the ribbon.
    • Use the tweezers to carefully pull out the LCD screen with the ribbon from the camera.
  10. Casio Exilim EX-Z850 Motherboard Replacement: 步骤 10 中的图像 1,2 Casio Exilim EX-Z850 Motherboard Replacement: 步骤 10 中的图像 2,2
    • Using the Phillips #00 screwdriver, remove two screws on the side where the battery is located.
    • Remove the lanyard loop after the screws come off.
    • Pull the side casing so it becomes dislocated from the top of the camera frame.
  11. Casio Exilim EX-Z850 Motherboard Replacement: 步骤 11 中的图像 1,2 Casio Exilim EX-Z850 Motherboard Replacement: 步骤 11 中的图像 2,2
    • On the front of the camera near the flash, flip the connector holding the ribbon.
    • Remove the ribbon from the connector.
  12. Casio Exilim EX-Z850 Motherboard Replacement: 步骤 12 中的图像 1,3 Casio Exilim EX-Z850 Motherboard Replacement: 步骤 12 中的图像 2,3 Casio Exilim EX-Z850 Motherboard Replacement: 步骤 12 中的图像 3,3
    • Carefully remove the L-shaped frame from the camera.
    • The L shaped frame is being held in by two plastic bumps and a metal tab at the bottom of the camera.
    • Pop the frame off the bumps and tabs.
    • Potential for device damage: Be careful not to pull off the yellow and orange wire soldered onto the camera.
  13. Casio Exilim EX-Z850 Motherboard Replacement: 步骤 13 中的图像 1,2 Casio Exilim EX-Z850 Motherboard Replacement: 步骤 13 中的图像 2,2
    • Flip the connector and remove the ribbon cable from the motherboard next to the lens.
  14. Casio Exilim EX-Z850 Motherboard Replacement: 步骤 14 中的图像 1,2 Casio Exilim EX-Z850 Motherboard Replacement: 步骤 14 中的图像 2,2
    • Remove the frame on the back side of the camera where the LCD screen was.
    • Use the Phillips #00 screwdriver to remove the two screws connecting the frame to the camera.
    • Slowly pry off the frame from the camera.
    • After removing the frame, a plastic piece with two yellow buttons should fall off.
    • Do not pull the plastic piece off as it is soldered to two wires: a yellow and orange one.
  15. Casio Exilim EX-Z850 Motherboard Replacement: 步骤 15 中的图像 1,1
    • On the back of the camera where the LCD screen was, remove the 3 screws located behind the lens using the Phillips #00 screwdriver.
  16. Casio Exilim EX-Z850 Motherboard Replacement: 步骤 16 中的图像 1,1
    • Remove the large orange ribbon previously held in by screws from the camera.
  17. Casio Exilim EX-Z850 Motherboard Replacement: 步骤 17 中的图像 1,1
    • On the backside of the camera where the indicator lamp is located, remove the two screws using the Phillips #00 screwdriver.
  18. Casio Exilim EX-Z850 Motherboard Replacement: 步骤 18 中的图像 1,3 Casio Exilim EX-Z850 Motherboard Replacement: 步骤 18 中的图像 2,3 Casio Exilim EX-Z850 Motherboard Replacement: 步骤 18 中的图像 3,3
    • On the front side of the indicator lamp remove the screw using the Phillips #00 screwdriver.
  19. Casio Exilim EX-Z850 Motherboard Replacement: 步骤 19 中的图像 1,2 Casio Exilim EX-Z850 Motherboard Replacement: 步骤 19 中的图像 2,2
    • Desolder the lens from the motherboard.
    • Desolder the wire from the motherboard.
    • The motherboard is now detached from the rest of the camera.
结论
另外一个人完成了本指南。
Jennifer Roth
于01/28/11注册
162 声望
撰写一个指南
团队
Cal Poly, Team 4-38, Regan Winter 2011 Cal Poly, Team 4-38, Regan Winter 2011 的会员
CPSU-REGAN-W11S4G38
4 名成员
创作了13篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 7
总计 3,848
