当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Use the Phillips #00 screwdriver to remove all four of the screws on the bottom of the camera.
Bottom screws are longer than the top screws, so label accordingly for easy reassembly.
Once all screws have been removed, slowly pry open the back casing of the camera.
Gently remove the ribbon cable from the LCD with tweezers.
Set aside back casing of the camera.
The bottom of the LCD screen is secured to the frame by small pieces of black tape. You will need to peel the tape away to release the LCD screen.
Use your tweezers to lift the LCD screen from the frame.
Use your tweezers to lift the bar holding the ribbon off.
Disconnect the ribbon to release the LCD screen.
Use your fingers to pull the LCD screen with the attached ribbon from the camera.
Use a Phillips #00 screwdriver to remove the two screws from the side of the camera that has the strap mount.
Remove strap mount by slowly pulling the side of the case so it will dislocate from the top of the camera.
With the lens facing towards you, pull the L-shaped frame away from the camera.
Do not disconnect any of the wires from the camera when pulling the frame.
Remove the frame from the two studs and metal tabs keeping it in place at the bottom of the camera.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
